Hello,
I have the above block on my guilds page, and we've recently changed styles. Unfortunately the background for the block is pulling in the border colors which makes it very difficult to read.
How could I add a set background color? I've tried adding a background color to the html file but it didn't seem to pick this up.
Any help would be appreciated.
Warcraft Guild Recent Activity Block
gazmon
- phpBB.de User: gazmon
- phpBB.com User: gazmon
talonos
- Portal Specialist
- phpBB.com User: talonos
Re: Warcraft Guild Recent Activity Block
have you a link to your portal so i can look into it for you.
gazmon
talonos
- Portal Specialist
ok heres a fix.
in styles/wowwarlords/template/portal/modules/wow_recent.html
find
near the bottom of that file
and replace with
clear your styles cache and it should be good to go.
find
<div class="panel bg1" style="margin-bottom: 0px">
<div class="postbody" style="width: 100%">and replace with
<div class="panel bg2" style="margin-bottom: 0px">
<div class="content"><span class="portal-corners-top-inner"></span>
<div class="postbody" style="width: 100%">Creating board3 website? check the sites out below for board3 compatible extensions
gazmon
Ah that's amazing thank you so much!
talonos
- Portal Specialist
glad to see it working right on your forums now
