forum is a way to close the blocks , how do I get this option also in the portal , the collapse block
collapse block portal
grazia
grazia
Re: collapse block portal
no idea for me please
- phpBB.de User: Kirk
grazia
I installed phpBB 3.1.6 with Board3 Portal 2.1 and I see in the forum there is a chance you close the block , but there is no portal
grazia
my link This
Thank you
Thank you
Copy the graphic collapse-icon.png in the directory root/styles/aero/images to root/ext/board3/portal/styles/all/theme/images/portal
Open: root/ext/board3/portal/styles/prosilver/template/portal/_block_config.html
Swap all the code with those from:
Open: root/ext/board3/portal/styles/prosilver/template/portal/portal_body.html
Find:
Add before:
Find:
Add after:
Open: root/ext/board3/portal/styles/all/theme/portal_all.css
Find:
Add after:
Purge the cache on ACP and your Browser cache
Note:
Testet with Board3 Portal 2.1.0
This works only with the Aero Style!
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg" role="row"><div class="inner"><ul class="topiclist"><li class="header"><dl><dt style="padding: 0px 0px 2px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt><dd></dd></dl></li></ul><ul class="topiclist forums"><div class="trigger active"></div><div class="collapsethis"><li><dl><dt></dt><dd class="portal-side-wrapper"><div class="portal-side">' -->
<!-- DEFINE $LR_BLOCK_F_L = '</div></div></dd></dl></li></ul>' -->
<!-- DEFINE $LR_BLOCK_F_R = '</div></div><br class="portal-clear" />' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="forabg" role="row"><div class="inner"><ul class="topiclist"><li class="header"><dl class="icon"><dt>' -->
<!-- DEFINE $C_BLOCK_H_R = '</dt><dd></dd></dl></li></ul><div class="trigger active"></div><div class="collapsethis">' -->
<!-- DEFINE $C_BLOCK_F_L = '</div>' -->
<!-- DEFINE $C_BLOCK_F_R = '</div></div><br class="portal-clear" />' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="forabg" role="row"><div class="inner"><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</dl></li></ul><div class="trigger active"></div><div class="collapsethis">' -->
<!-- DEFINE $PORTAL_RIGHT_COLUMN_OVERRIDE = '200' -->Find:
<div id="portal-body" role="grid">Code: Select all
<div class="forumlist">
<!-- [-] bottom module area -->
</div>Code: Select all
$(".forumlist").collapse({show: function(){
this.animate({
opacity: 'toggle',
height: 'toggle'
}, 300);
hide : function() {
this.animate({
opacity: 'toggle',
height: 'toggle'
}, 300);
</script>
</div>Find:
.rtl ul.topiclist dt {
margin-left: -440px;
}Code: Select all
.trigger {
background: url("./images/portal/collapse-icon.png") no-repeat;
cursor: pointer;
float: right;
height: 17px;
margin-top: -21px;
position: relative;
width: 23px;
.active {
background-position: left top;
.inactive {
background-position: left -17px;
.active:hover {
background-position: left -34px;
.inactive:hover {
background-position: left -51px;
Note:
grazia
Great ,, you were really very kind , thank you from the heart
