Extension Name: B3P National Flags
Addon Author: theriddler
Extension Description:
phpBB 3.1 extension module for board 3 portal show national flags from rmcgirr83.
Addon Requirements: phpBB 3.1.5, Board3 Portal 2.1.0 or newer and National flags Extension by rmcgirr83
Extension Version: 1.0.1
Extension Download:
https://www.phpbbservice.nl/forum/viewt ... 16&t=12555
Installing the extension:
After downloading unzip this file and upload the whole folder theriddler root/ext.
In the administration panel under Customize -> Extensions Administrative Tools -> Extensions Disabled
in line B3P national flags module click Enable.
Click on the Add button module> Portal modules in the desired column and select the module from the drop-down list - In the administration panel under Extensions -> Portal.
Note!
The extension National flags must be pre-installed and activated!
***If you need another b3p module extension you can always send me a private message.
[RELEASE]B3P National Flags
Theriddler
talonos
- Portal Specialist
- phpBB.com User: talonos
Re: [RELEASE]B3P National Flags
no download link on that page.
Theriddler
the zip file at the download link is back.talonos wrote:no download link on that page.
