Please post general support questions for the phpBB3 core system on
phpBB.com !
Bitte allgemeine Supportanfragen zu phpBB3 auf
phpBB.de stellen!
phpBB.com !
phpBB.de stellen!
j.rhy@n
Posts: 35 Joined: 6. October 2008 13:02
Post
by j.rhy@n » 8. October 2008 12:57
Boardlink: http://www.j-rhyan.de
Research
Nothing
When click on The Team, how is it possible to add more groups..
Example: News Poster
Here is the code for the Leaders Block
<!--version $Id: leaders.html 302 2008-08-13 01:48:29Z icedcold $ //-->
<div class="portal-panel">
<div class="inner">
<h3><img src="{T_THEME_PATH}/images/portal/portal_team.gif" width="18px" height="18px" alt=""/> {L_THE_TEAM}</h3>
<strong>{L_ADMINISTRATORS}</strong><br />
<!-- BEGIN admin -->
<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/member.gif" height="15" width="15" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;"><strong>{admin.USERNAME_FULL}</strong></span><br style="clear:both" />
<!-- BEGINELSE -->
{L_NO_ADMINISTRATORS_P}<br /><br />
<!-- END admin -->
<strong>{L_MODERATORS}</strong><br />
<!-- BEGIN mod -->
<span style="float:left;"><img src="{T_THEME_PATH}/images/portal/member.gif" height="15" width="15" alt="" /></span><span style="float:left; padding-left:5px; padding-top:2px;"><strong>{mod.USERNAME_FULL}</strong></span><br style="clear:both" />
<!-- BEGINELSE -->
{L_NO_MODERATORS_P}
<!-- END mod -->
Thx for any info[/i]
Ice
Posts: 359 Joined: 20. January 2008 23:43
Post
by Ice » 8. October 2008 13:45
If you use the extended version then all of the groups you select to display under "Who's online" will also be displayed on the team block.
j.rhy@n
Post
by j.rhy@n » 8. October 2008 13:56
Hi Ice..
Can you explain a little more please, not sure I follow what you mean..
Ice
Post
by Ice » 8. October 2008 15:20
ACP -> .MODS -> Portal -> General Settings -> Extended Leaders / Team
j.rhy@n
Post
by j.rhy@n » 8. October 2008 16:34
Hi Thx for reply..
Its already enabled...
Under "The Team" again only shows 2 Groups - Admin and Mods..
Posts: 2994 Joined: 7. January 2006 20:11
Post
by Kevin » 8. October 2008 17:43
There is no team-block on your site visible at all?
Post
by Kevin » 8. October 2008 19:02
I can't see the memberlist, as I'm not registered.
But now the team block shows up on the portal the portal:
The team
Administrators
J.Rhy@n
News Poster
DMD100
So everything is fine?
Post
by Kevin » 8. October 2008 20:17
It's definitely not a portal issue.
Moved to the general support forum.
Ice
Post
by Ice » 8. October 2008 21:17
That Team is part of phpBB3 not the portal, no wonder I had no idea what you were on about. XD
