Updated Board, Portal no longer front page
JohnnyBigspuds
phpBB.com User: JohnnyBigSpuds
Post by JohnnyBigspuds »
Updated my board from phpbb 3.1.2 to 3.1.8 then to 3.1.11
Portal page no longer shows on as main website page, not to sure when it happened
The portal can be accessed by clicking on the portal link
and the side portal is all displayed correctly on all pages
Since the update, the landing page of the site is now the index page.
I have followed numerous topics to resolve this and havent been able to get it to work
prior to updates, when you went to " test.com " it shows the portal page and the http address bar was
www.test.com
now it shows the index page.
To have the portal page show as main page now have to have the http address bar as
www.test.com/app.php/portal
i have made the following changes but it hasnt rectified the issue ( i have also purged the cache )
Open includes/functions.php
Find:
$redirect = request_var('redirect', "{$phpbb_root_path}index.$phpEx");
Replaced with
$redirect = request_var('redirect', "{$phpbb_root_path}YOUR PAGE NAME.$phpEx");
And
Open root/.htaccess
Add
DirectoryIndex app.php index.php index.html index.htm
And
In ucp.php find:
    case 'login':
            redirect(append_sid("{$phpbb_root_path}index.$phpEx"));
        login_box(request_var('redirect', "index.$phpEx"));
Replaced with
    case 'login':
            redirect(append_sid("{$phpbb_root_path}portal.$phpEx"));
        login_box(request_var('redirect', "portal.$phpEx"));
Can anyone please help?
many thanks
Re: Updated Board, Portal no longer front page
Open: root/.htaccess
Insert the end:
JohnnyBigspuds
Thank you for approving my topic.
Alas the modification above has not worked either.
any other ideas? or info i could provide?
board is forumbook style based on prosilver
root is your forenroot where the config.php is located.
JohnnyBigspuds
Kirk wrote: 8. November 2017 14:58 root is your forenroot where the config.php is located.
yes, the same location as .htaccess file
my board URL is
http://ukgunbook.com/
Interestingly, when logging out, you get returned to the portal page
JohnnyBigspuds
It solved itself, but a new problem developed
when using the login from the portal user menu its fine, it logs straight in
BUT if i try and log in from anywhere else on the board i get the error
" No route found for "GET /portal.php "
What do you mean by
"BUT if i try and log in from anywhere else on the board i get the error"
There is no portal.php under phpBB 3.1
JohnnyBigspuds
exactly, i appear to have an error that affects logins somewhere but cannot locate it
i have made a vid clip showing what i mean
https://www.youtube.com/watch?v=ISJjs_Z3mms
This login logout function has nothing to do with the portal. Question on phpBB.com afterwards.
JohnnyBigspuds
Solved it
in the ucp.php there were incorrect edits
there was redirects to app.php/portal
i changed them to app.php
and now is fully working
JohnnyBigspuds wrote: 11. November 2017 15:53 exactly, i appear to have an error that affects logins somewhere but cannot locate it
Successfully tested for phpBB 3.1.11 / phpBB 3.2.1
Make the original again and try my changes:
Redirect login / logout for phpBB 3.1.11 / phpBB 3.2.1 to Board3 portal
open: root/.htaccess
for phpBB 3.1.11
open: root/ucp.php
		login_box(request_var('redirect', "app.$phpEx"));
			$message = $user->lang['LOGOUT_FAILED'] . '<br /><br />' . sprintf($user->lang['RETURN_INDEX'], '<a href="' . append_sid("{$phpbb_root_path}index.$phpEx") . '">', '</a> ');
			trigger_error($message);
		redirect(append_sid("{$phpbb_root_path}app.$phpEx"));
for phpBB 3.2.1
open: root/ucp.php
		login_box($request->variable('redirect', "index.$phpEx"));
		login_box($request->variable('redirect', "app.$phpEx"));
