How to make an extension work in the latest Board 3 Portal?
Topic: https://www.phpbb.com/customise/db/exte ... ar_status/
Discussion of the topic here: https://www.phpbb.com/customise/db/exte ... pic/215056
Member Avatar & Status Error
TrekRed
TrekRed
Re: Member Avatar & Status Error
Is there a solution? The extension inherits the Prosilver style!
TrekRed
I don’t understand if there will be a solution?
- phpBB.de User: Kirk
TrekRed
Maybe then you will make a module that displays something similar near a nickname or avatar? Your development!
