Hello,
Firstly, thank you for such a great add-on to phpBB!!
How can I make the Portal page default?
Right now it defaults to "Board index".
Theme: prosilver French edition by phpBB-fr.com
Thank you.
Board3 Portal "default"?
Karado58
- phpBB.com User: Karado58
Re: Board3 Portal "default"?
Please look here: Portal as Site Main Page
Karado58
Hello @archivar
Fantastic tutorial!!
The second method worked beautifully!!
Create a file called portal.php with the following content:
Replace the xxx with the URL to your forum. Load this file into your forum root (where the config.php is located).
Open: root/.htaccess
Insert this at the very end:
Thank you!!!
header("Location: https://xxxxxxxxxxxx/app.php/portal");
exit;Replace the xxx with the URL to your forum. Load this file into your forum root (where the config.php is located).
DirectoryIndex portal.php index.php index.html index.htmThank you!!!
