Only two attachments in the latest news in large settings
Current Version: 2.3.0
Released: 2023-03-19
Jambore
Post by Jambore »
What if I only need to display two attachments on the home page?
{% if 2 S_HAS_ATTACHMENTS %}
Re: Only two attachments in the latest news in large settings
Where exactly should this be displayed?
Jambore
Post by Jambore »
I'm just asking how to edit the code?
If I only want to display two attachments on the portal.
If you mean the Latest news modules, it is not possible. Either display all attachments in the post or nothing.
Jambore
Post by Jambore »
Couldn't this be modified in the code?
For example, if there are six attachments, I don't want to show them all, but only two.
Otherwise the page is stretched.
Or would it be possible to order the attachments side by side using css at least?
On larger displays it would look better.
Thank you for your suggestions.
It might be possible, but it would require many changes.
For attachments side by side, look here: Horizontal Attachments
Jambore
Post by Jambore »
Kirk wrote: 6. February 2024 17:06 It might be possible, but it would require many changes.
Would it be possible to implement Topic Image Preview on the portal homepage?
No images would be displayed, but attachments would be displayed when you HOVER on the title.
Topic Image Preview
https://www.phpbb.com/customise/db/exte ... e_preview/
Ask the extensions author about it.
Jambore
Post by Jambore »
Would it be possible to wrap attachments, photos in a spoiler using code on the portal homepage?
For example:
Simple Spoiler BBCode extension for phpBB
https://www.phpbb.com/customise/db/exte ... er_bbcode/
Or just edit the code for this option?
Only on the portal is not possible. This needs to be included in the topics.
Jambore
Post by Jambore »
Kirk wrote: 8. February 2024 19:07 Only on the portal is not possible. This needs to be included in the topics.
:arrow: Well, would it be possible to hard code it?
I just need to know the code. Where do I copy it?
There might be a solution, but it needs to be tested first.
Test this one:
Note: Does not work with inline attachment!
Open: root/ext/board3/portal/styles/prosilver/template/portal/modules/news_center.html
Find:
					{% if news_row.S_HAS_ATTACHMENTS %}
						<dl class="attachbox">
							<dt>{{ lang('ATTACHMENTS') }}</dt>
							{% for attachment in news_row.attachment %}
								<dd>{{ attachment.DISPLAY_ATTACHMENT }}</dd>
							{% endfor %}
						</dl>
					{% endif %}
Replace with:
						<details class="portal-attachment-spoiler">
							<summary class="portal-attachment-spoiler-text">
							</summary>
							<div class="portal-attachment">
									{% endfor %}
								</dl>
						</details>
					{% endif %}
Open: root/ext/board3/portal/styles/prosilver/theme/portal.css
Insert at the end:
/* Portal Attachment Spoiler */
details.portal-attachment-spoiler {
	background-color: #EDE8E0;
	border: 1px solid #CDC8C0;
	margin: 1em 0;
summary.portal-attachment-spoiler-text {
	display: list-item;
	cursor: pointer;
	font-size: 1.1em;
	padding: .5em;
.portal-attachment {
	border-top: 1px solid #CDC8C0;
	display: list-item;
	cursor: pointer;
	padding: .5em;
	list-style-type: none;
	font-size: 13px;
	cursor: default;
.portal-attachment .attachbox {
	float: none;
	width: max-content;
In the end "ACP -> General" --> purge cache It's recommended to purge your browser cache too.
You will have to make further changes or adjustments yourself.
Return to “Board3 Portal 2.3.x - English Support”
