Search function issue
Hi, although I changed nothing in portal setting, word graph is now displayed in strange way - see below. Same situation is for both prosilver and subsilver style. Do you know any solution for this behaviour?
Re: Word Graph issue
Do you mean the font size of the words or that all words have the count of 5?
The font size could be set in the ACP.
both is problem. In my forum there is more than 100 replies, so number of words is definitely more than 5. Problem is not in style, but in counting of results.
Would you mind to give me a link to your board?
sure - http://www.belariepark.cz
Maybe one more thing - in my forum I wrote this replay:
If e-mail address admin@belariepark.cz was not in the brackets everything looked ok. But if it was, portal page looked strange - see below. Problem was with right bracket ...
Máte na mysli B.Bedná?ovou z právního odd?lení? Já psal maily na jejich oficiální e-mailovou adresu prodej@cnas.cz, ale jak jsem ?íkal, všechny z?staly bez odpov?di. Te? jsem alespo? chyt?ejší, díky za tip ;)
Pokud jde o fotky, tak je m?žete p?idat p?ímo do Galerie, p?ípadn? mi je m?žete poslat mailem na adresu admin@belariepark.cz a já je tam p?idám sám.
Jen ze zv?davosti - jedná se o fotky p?ímo Vašeho bytu nebo Vám z ?N poslali na ukázku pár obecných fotek z vnit?ku stavby?
P.S. P?edpokládám, že jste se k fotkám dostal op?t p?es pí Bedná?ovou, je to tak?
The wordgraph counts in how many posts the word is found.JirkaX wrote:both is problem. In my forum there is more than 100 replies, so number of words is definitely more than 5.
e.g "pod" is found in 5 posts - the search functions sais the same: http://www.belariepark.cz/search.php?keywords=pod
"Vyhledáváním bylo nalezeno 5 výsledk?: pod"
Same with all the other words. So everything is fine and is working properly. Just adjust the font size.
The other problem is a bug which is coming up under very rare circumstances: cutting the text in the news in the middle of an mailadress.
Please adjust the number of chars from which on the text should be cut, put the mailadress in brackets or remove it. We don't have a fix for that already.
Yes, I know word graph function. But according to the current results most common words are these ones which appear 5 times in whole forum .... which is wrong. There are other words which apper more than 5x and they are not mentioned in word graph block.
So in my opinion something is wrong, but I don't know what and how to fix it ...
Hi, any idea how to solve this issue with wrong word frequency?
I haven't seen any issue and don't think that somethings wrong.
Give me an example directly with your search function which words you mean.
Ok, no problem. According to the word grapg block the highest word frequency is 5. But there are other words with frequency much higher, for example "jsem". But now when I wanted to find out how many times this word appear, I realised that search function doesn't work. For words shown in word graph it works fine, but for some others it doesn't. When I try "jsem" or "centrum", I get following answer: The following words in your search query were ignored because they are too common words: jsem.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards.
But it doesn't make any sense, because both words have more than 3 letters ....
I know this issue is not directly related to portal, but do you know any reason/solution for this?
At first i would recommend to create the search index new (always do so each time you have made changes to the search settings):
ACP --> Maintenance --> Search index --> "Delete index"
Afterwards: "Create index" and wait until it's done.
I followed your instructions - deleted old index and created new one. But search issue still occurs .... do you have nay other idea how to solve it?
Purged cache?
Try controlling / changing your search settings and go for creating the index again.
Do you use fulltext mysql or fulltext native?
Fulltext mysql is not supported by the wordgraph.
If all this doesn't end up in the wished result, i would recommend to ask at phpbb.com, as this is no portal issue.
Moved topic to general phpBB3 support.
Re: Search function issue
I tried to do it again - I checked my settings (see below), deleted and created index and purged cache .... but search still doesn't work properly. I will try to ask on phpbb.com forum.
I would try to set the "common word threshold" to zero.
Create the search index new afterwards.
Then this error message should disappear:
And i can imagine that your problem is solved then.The following words in your search query were ignored because they are too common words
