I want to use just the center and right blocks – in other words, having the center block take up the space of the left and center columns. I know I can just move all the left blocks in portal_body.html over to the right block section and delete the left block section entirely.
But I was wondering if there was a more proper way to do that via database schema changes and changes to the ACP as well in addition to the changes in portal_body.html.
Or is that not really worth the trouble? As far as I can tell, the result seems to be the same anyway.
Just Center and Right Blocks
Re: Just Center and Right Blocks
What should be done? What are you thinking about exactly? There is nothing to do in that direction, as far as i understand you. At least nothing necessary.the.ronin wrote:But I was wondering if there was a more proper way to do that via database schema changes and changes to the ACP as well in addition to the changes in portal_body.html.[/i]
I'd say: yes, exactly.the.ronin wrote:Or is that not really worth the trouble? As far as I can tell, the result seems to be the same anyway.
