4 columns in portal
Moderator: Dyo
ginja
4 columns in portal
Post by ginja »
hello :)
so i have board3 installed on a new phpbb 3.0.4 forum
i had a little padding problem (the left column was sticked to the left and the right to the right)
i didn't think it was a major problem, and that i could fix this with a few changes in the css.
but i didn't found the way to change this yet.
then i wanted to install this mod to have only a left side in the whole forum.
i think i followed every steps to install this mod
but now i have 2 left columns and 2 right columns on the portal
and on the rest of the forum, everything is working nicely, even the 'padding'
are those 2 problems related ?
any thing i have to check to fix the 2 left and right problems ?
any simple way to ad only a left column to the whole forum and both column in portal ?
thanx
ginja
Re: 4 columns in portal
Post by ginja »
nvm lol
i forgot to upload the edited portal_body file
now its working perfectly
better in the index and the whole forum than the portal itself as the portal dont have padding.
i will have to check where the problem comes from.
thanx for this great mod
ginja
Post by ginja »
for the padding,
there seems to be a problem with the wrap div that doesn't contain the whole page like it is in the rest of the forum.
any idea where to check ?
also i'd like to have the index and topics with only a left side while the portal still have both sides and center.
is it possible ?
i only manage to remove the right side completely, but thats not what i'd like
ginja
Post by ginja »
thats where i am, what are you trying to say ?
am i in a wrong section ?
Oh, sorry. Missed that! :?
ginja
Post by ginja »
lol
no problem dude, we are humans, and my 3 posts above aren't very clear :oops:
in one word now my question is:
how can i get only the left side on index and keep the portal with both right and left side ?
btw happy new year :)
ginja
Post by ginja »
ok
i've found out how to do what i want.
if this may help someone, i just make a copy of the overall_footer.html and called it overall_footer2.html
then i edited the viewtopic_body.html and replace the last lign by this <!-- INCLUDE overall_footer2.html -->
so it will take that other version of the footer
and i deleted all between :
<!-- [+] right block area -->
and
<!-- [-] right block area -->
in that overall_footer2.html
so now the topics are showing without the right column and are less stretched for the low resolutions
it works like a charm now
thanx for these mods :ugeek:
Dyo
Tester
Post by Dyo »
Its fine if everything works now.
if you had a bit more time, you could save a lot of time, cause this is already in use for another forum i administrate.
regards dyo
Es gibt so viele schlaue Signaturtexte, nur mir fällt grade nix vernünftiges ein.
Da sieht man mal für wie wichtig ich eine Signatur halte, Fliegendreck auf dem Monitor ist wichtiger für mich.
In welcher Hinsicht überlasse ich der Phantasie des Lesers.
