Your Portal Version: 1.0.2
Boardlink: http://nifclan.co.uk/andytest1/
This is a clean install and havent fitted any other mods.I have tried this on a test board.
Ive looked on the forums and found no help with this matter
While installing the portal i had this error
General Error
Language file ../language/en_us/mods/portal_install.php couldn't be opened
Well i know this actually isnt on my server as its not in that structure when you upload it so what is wrong ?
Also when i load up forums now i get this
General Error
SQL ERROR [ mysql4 ]
Table 'nifclan_phpb2.phpbb_portal_config' doesn't exist [1146]
I uploaded all the files as i should,and followed the install instructions to the letter.
Many thanks in advance
Andy
Install error
thomas.d
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: Install error
Hi Andy,
... no, you didn't.andymorris wrote:... I uploaded all the files as i should,and followed the install instructions to the letter. ...[/i]
says clearly,that the file is actually not where it's supposed to be. This may help knowledge/kb_show.php?id=30Language file ../language/en_us/mods/portal_install.php couldn't be opened
... have you ran the installer?Table 'nifclan_phpb2.phpbb_portal_config' doesn't exist
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
andymorris
Re: Install error
yes ive ran the installer ...
Ididnt realise the phpbb3 forum that was setup was english us by default
*Edit* Im a noob worked it out from what you said ..thanks and i have a running one now,i did clean install as its just a test one for me
