Forumlist in Menu
Darkheart
Forumlist in Menu
Post by Darkheart »
ABOUT:
## Title: Forumlist in Menu for Board3
## Author: Darkheart, http://ankh.id.lv
## Description: Adds a forumlist to your Board3 portal menu with Categories in main menu and Forums in submenu.
##              JavaScript code part based on AnyLink Vertical Menu by © Dynamic Drive (www.dynamicdrive.com).
## Version: 1.0
## Installation Level: Easy
## Installation Time: ~3 minutes
## Files to edit:
## includes/functions_display.php
## portal.php
## styles/prosilver/template/portal/block/main_menu.html
## styles/subsilver2/template/portal/block/main_menu.html
Download:
http://ankh.lv/downloads/Forumlist_in_M ... 3_v1.0.txt
Re: Forumlist in Menu
Nice one, thanks for sharing, Darkheart! :D
thomas.d
phpBB.de User: thomas.d
phpBB.com User: thomas.d
Post by thomas.d »
Oh ja, very nice!
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
amroth
Post by amroth »
For me the problem is that when going over it with the mouse the subforums not be Displayed.
my page http://www.religions-of-azeroth.de
Where is the error?
< Wir Suchen GM's | Scripter / Bugfixxer | Foren Moderatoren | Foren Designer >
amroth
Post by amroth »
push
Darkheart
Post by Darkheart »
amroth, sorry for the late answer, but I see you have fixed that error.
I recommend you to change the background and font color of your submenu ;)
Greight
phpBB.com User: Greight
Post by Greight »
Ca u make this menu one level down. U know my forum has lots of categories and this way it will take a lot of aspace. So I want when u put the pointer on the menu u get to the list of categories and so forth. I dun know whether I could explain what I want well or not.
Ypselon
Post by Ypselon »
This ist what i need :)
But i have an Problem .. i have an Forum for 2 Big Guilds, so i will use this Mod to display Links for Guildinfos and own URLs.
Any Know what must i change, so that i can display my own links Instead of Forum Categories ?
Greight
Post by Greight »
Where is
<div class="portal-panel">
There is no "portal-panel" anymore. Now it's just "panel" as far as I know.
simonjcook
Post by simonjcook »
I can't locate the insert point in the main_menu.html file either.
Board3 Portal version 1.0.3.
Can you give some updated instructions please?
simonjcook
Ignore me - wrong template main menu :)
Awesome - got it working, thank you.
It needs multiple menu levels though (as someone pointed out above) to give direct access to sub-forums via the popup menu.
Otherwise I'm going to have to re-arrange my forum hierachy into a flat list which isn't so good.
Graaft
phpBB.de User: Graaft
phpBB.com User: Graaft
Post by Graaft »
works great, but is it possible to show the menu also if i am in an Forum?
If i skip into a Forum the Navigation-Bar disappars and there is only the "normal" menu left
mladiucitelj
Post by mladiucitelj »
Great mod, but when I login to portal the mouseover for subforums is not working. When I'm not loged in everything is doing fine. Can anybody help me?
mladiucitelj
Please, I would really like to get this working right, but I don't know how to fix it. Any help?
