Hello!
How to display right blocks?
Wie die Anzeige der rechten Blöcke?
Portalview: How to display right blocks?
Moderator: Dyo
Bruno36
- phpBB.de User: bruno36
- phpBB.com User: bruno36
Bruno36
Re: Portalview: How to display right blocks?
you never answer questions?
ralf-isi
- Valued Contributor
- phpBB.de User: ralf-isi
I not understand your question - can not be English.
the right blocks are in the overall_fooder.html defined.
<br clear="all" />
<div class="copyright" align="center">{L_PORTAL_COPY}</div>
<!-- [-] center block area -->
<td style="width:4px;" valign="top"> </td>
<!-- [+] right block area -->
<td width="{PORTAL_RIGHT_COLUMN}px" valign="top" style="padding-left:6px;">
<!-- IF S_DISPLAY_USERMENU -->
<!-- INCLUDE portal/block/login_box.html -->
<!-- INCLUDE portal/block/user_menu.html -->
<br clear="all" />
</body>
</html>
Bruno36
Merci ralf-isi
