How do I make the portal my homepage?
Frog
Post by Frog »
I figured I'd just put portal.php and the portal folder in the root directory to make the portal my homepage but it doesn't work. When I go to mysite.com/forum it goes to the portal and I want it to go to the forum and when I go to mysite.com I want it to go to the portal.
Similar to this site.
Thanks for any help!
vengeance
phpBB.de User: vengeance
phpBB.com User: vengeance
Re: How do I make the portal my homepage?
Post by vengeance »
Frog
Post by Frog »
Thanks for link. It worked but...
I want it to be so mysite.com goes right to the portal. Right now it goes to my ftp index. However mysite.com/portal.php goes to the portal.
Frog
Post by Frog »
Nah that's not my problem. I can see the .htacess file and I edited it. my portal is at myssite.com/portal.php I want it to appear at mysite.com without entering the portal.php part.
Thanks though.
This is done with the edits in the .htaccess, as stated in the install.xml:
portal_docs/install.xml#.htaccess
Frog wrote:Nah that's not my problem
Quote from the linked Article:
In some cases it is neccessary to edit the .htaccess file, especially when you want to direct your users to the portal page (portal.php) as the front page of your forum instead of the forum index (index.php).
That means that you just have to enter yoursite.com (instead of yoursite.com/portal.php) to see the Portal.
Isnt that exactly what you want?
Frog
Post by Frog »
Yes but that topic dealt with finding the .htaccess file which isn't hidden for me and I made the changes noted in the thread and it still didn't work but then I realized that the permissions wouldn't let the .htaccess file be edited. Anyway it's solved now so thank you for the help and links everyone.
I just have one completely off-topic question that I don't want to make a new thread for. When someone is viewing mysite.com (which is now the portal) does it record the guests on the who's online box on the forum?
just wondering Thanks
Yes... it does ;)
