Recent Topics Scrolling
DragonMaster
phpBB.com User: DragonMaster1
Post by DragonMaster »
I see that there is a Recent Topics small block that is scrolling here:
http://www.livewiremods.com/mods/viewforum.php?f=2
Anyone know where to get that block code?
Thanx In Advance!!!
Re: Recent Topics Scrolling
I think this is part of the stargate portal code. You might have a look on it.
DragonMaster
I have that as it was one I was thinking of using, but it was still not as nice as this one. I’ll take a look at the blocks but so far I had not had any luck getting them to work on this board
DragonMaster wrote:but so far I had not had any luck getting them to work on this board
It should be possible.
If you have it downloaded yet, please show me the content of the belonging files. We might offer an adaption with respect to their work and credits.
DragonMaster
Here is my base test board I made for it:
http://www.ronnie-james-dio.com/PORTALT ... 5d8b6c9465
Here is the Recent Topic code
 *                          block_recents_topics.php
 *   begin                : Sunday, 20th May, 2007
 *   copyright            : (C) 2005 Michaelo - Michael O'Toole
 *   website              : http://www.phpbbireland.com
 *   email                : admin@phpbbireland.com
 *   last update          : 21 February 2008
 *   licence              : GPL vs2.0 [ see /docs/COPYING ]
 *   Note: Do not remove this copyright for the top of this page. Just
 *   append yours if you have modified it.  Do not remove copyright...
if ( !defined('IN_PHPBB') )
	die("Hacking attempt");
$auth->acl($user->data);
// URL PARAMETERS
define('POST_TOPIC_URL', 't');
define('POST_CAT_URL', 'c');
define('POST_FORUM_URL', 'f');
define('POST_USERS_URL', 'u');
define('POST_POST_URL', 'p');
define('POST_GROUPS_URL', 'g');
	global $user, $forum_id, $phpbb_root_path, $phpEx, $SID, $config , $template, $portal_config, $userdata, $config, $db, $phpEx;
	// set up variables used //
 	$display_this_many = $k_config['number_of_recent_topics_to_display'];
	$forum_count = $row_count = 0;
	$except_forum_id = '';
	$forum_data = array();
	$recent_topic_row = array();
	// get all forums //
	$sql = "SELECT * FROM ". FORUMS_TABLE . " ORDER BY forum_id";
	if (!$result = $db->sql_query($sql))
		trigger_error('Error! Could not query forums information: ' . basename(dirname(__FILE__)) . '/' . basename(__FILE__) . ', line ' . __LINE__);
	while( $row = $db->sql_fetchrow($result) )
		$forum_data[] = $row;
		$forum_count++;
	$db->sql_freeresult($result);
	for ($i = 1; $i < $forum_count; $i++)
		if (!$auth->acl_gets('f_list', 'f_read', $forum_data[$i]['forum_id']))
			$except_forum_id .= "'" . $forum_data[$i]['forum_id'] . "'";
			$except_forum_id .= ",";
	$except_forum_id = rtrim($except_forum_id,",");
	if($except_forum_id == '')
			$except_forum_id = '0';
	$sql = "SELECT t.topic_id, t.topic_title, t.topic_last_post_id, t.forum_id, p.post_id, p.poster_id, p.post_time, u.user_id, u.username, u.user_colour
		FROM " . TOPICS_TABLE . " AS t, " . POSTS_TABLE . " AS p, " . USERS_TABLE . " AS u
		WHERE t.forum_id NOT IN (" . $except_forum_id . ")
			AND t.topic_status <> 2
			AND p.post_id = t.topic_last_post_id
			AND p.poster_id = u.user_id
				ORDER BY p.post_id DESC
					LIMIT " . $display_this_many;
		if (!$result = $db->sql_query($sql, 300))
			trigger_error("Could not query recent topics data");
			$recent_topic_row[] = $row;
			if( $row['forum_id'] > 0)
				// Get forum name for this postid
				$sql2 = "SELECT forum_name
					FROM " . FORUMS_TABLE . "
					WHERE forum_id = " . $row['forum_id'] . "
					LIMIT " . 1;
				if (!$my_result = $db->sql_query($sql2, 300))
					trigger_error("Could not get forum name");
				$my_row = $db->sql_fetchrow($my_result);
				$recent_topic_row['forum_name'][$row_count] = $my_row['forum_name'];
				$row_count ++;
		$db->sql_freeresult($my_result);
		$sql = "SELECT scroll, position
		FROM " . K_BLOCKS_TABLE . "
		WHERE title = 'Recent Topics' ";
		if( $result = $db->sql_query($sql, 300) )
			$rowx = $db->sql_fetchrow($result);
			$scroll = $rowx['scroll'];
			$display_center = $rowx['position'];
		trigger_error("Could not query <strong>" . $recent_topics . "</strong> information");
		($scroll) ? $style_row = 'scroll' : $style_row = 'static';
		//$template->assign_block_vars($style_row, array());
		// change topics to display count if there are less topics that set in ACP
		if($display_this_many > $row_count)
			$display_this_many = $row_count;
		if($scroll)
			if($row_count <= 6)
				$template->assign_vars(array(
					'PROCESS'	=> false,
					'PROCESS'	=> true,
		for ( $i = 0; $i < $display_this_many; $i++ )
			if ($recent_topic_row[$i]['user_id'] != -1)
				if($display_center != 'C')
					$recent_topic_row[$i]['topic_title'] = sgp_checksize ($recent_topic_row[$i]['topic_title'],20); // Michaelo's function to stop page from stretching due to long names in form select options... Names are truncated//
				$view_topic_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($recent_topic_row[$i]['forum_id']) ? $recent_topic_row[$i]['forum_id'] : $forum_id) );
				// add spaces for nice scrolling
				$my_title = smilies_pass($recent_topic_row[$i]['topic_title']);
				$length = strlen($my_title);
				// padd if too long
				if($length > 25)
					sgp_checksize ($my_title, 25);
				// do same for forum name
				$my_forum = smilies_pass($recent_topic_row['forum_name'][$i]);
				$length = strlen($my_forum);
				// padd if too long
				if($length > 25)
					sgp_checksize ($my_forum, 25);
				$template->assign_block_vars($style_row . '.recent_topic_row', array(
					'U_FORUM'		=> append_sid("viewforum.$phpEx?" . POST_FORUM_URL . '=' . $recent_topic_row[$i]['forum_id']),
					'U_LAST_POST'	=> $view_topic_url . '&p=' . $recent_topic_row[$i]['topic_last_post_id'] . '#p' . $recent_topic_row[$i]['topic_last_post_id'],
					'U_TITLE'		=> append_sid("viewtopic.$phpEx?" . POST_POST_URL  . '=' . $recent_topic_row[$i]['post_id']),
					'S_FORUM'		=> $my_forum,
					'S_POSTER'		=> get_username_string('full', $recent_topic_row[$i]['user_id'], $recent_topic_row[$i]['username'], $recent_topic_row[$i]['user_colour']),
					'S_POSTTIME'	=> $user->format_date($recent_topic_row[$i]['post_time']),
					'S_ROW_COUNT'	=> $i,
					'S_TITLE'		=> $my_title,
					'LAST_POST_IMG'	=> $user->img('icon_topic_newest', 'VIEW_LATEST_POST'),
			'S_RECENT_TOPICS_COUNT_ASKED'		=> $display_this_many,
			'S_RECENT_TOPICS_COUNT_RETURNED'	=> $row_count,
			'S_ALIGN_IT'						=> 'center',
			'S_DISPLAY_CENTRE'					=> $display_center,
			'S_COUNT'							=> $display_this_many,
And the template code would be nice. :)
DragonMaster
Kevin wrote:And the template code would be nice. :)
That base I have is just basic prosilver....but I normally use Divine Black based on subsilver
However - i need a template. ;)
prosilver is fine - for other people, wanting to use it.
But please note: we are currently working on the next release of B3P. So it might be that i only get to have a look on it next week.
DragonMaster
Do you want my Divine Black?
If so, a base copy or the modded one I use?
Which files?
PeterS
phpBB.de User: PeterS
phpBB.com User: PeterS
Post by PeterS »
Hi Kevin,
here the block_recent_topics.html
<!-- IDTAG starts block_recent_topics.html 30th June 2008 copyright 2007 phpbbireland.com -->
<span class="block_data">
<!-- IF S_COUNT_RECENT -->
	<div style="width:100%; overflow:visible;" >
	<!-- BEGIN scrollwide -->
    <!-- BEGIN recent_topic_row -->
		<strong>{staticwide.recent_topic_row.ORI_LAST_POST_IMG} <a href="{scrollwide.recent_topic_row.U_TITLE}" > {scrollwide.recent_topic_row.S_TITLE}</a></strong>
		<br /> by: {scrollwide.recent_topic_row.S_POSTER}  <br />
		<span class="tiny">{scrollwide.recent_topic_row.S_POSTTIME}</span><br />
		<!--<a href="{scrollwide.recent_topic_row.U_TITLE}" >{L_RECENT_REPLY}{scrollwide.recent_topic_row.ORI_LAST_POST_IMG}</a><br /><br />-->
	<!-- END recent_topic_row -->
	<!-- END scrollwide -->
	<!-- BEGIN staticwide -->
		<strong>{staticwide.recent_topic_row.ORI_LAST_POST_IMG} <a href="{staticwide.recent_topic_row.U_TITLE}" > {staticwide.recent_topic_row.S_TITLE}</a></strong>
		<br /> by: {staticwide.recent_topic_row.S_POSTER}  <br />
		<span class="tiny">{staticwide.recent_topic_row.S_POSTTIME}</span> <br />
		<!-<a href="{staticwide.recent_topic_row.U_TITLE}" >{L_RECENT_REPLY}{staticwide.recent_topic_row.ORI_LAST_POST_IMG}</a><br /><br />-->
	<!-- END staticwide -->
	<div><center><span class="genmed"><strong>{L_NO_RECENT_TOPICS}</strong></span></center></div>
</span>
<!-- IDTAG ends block_recent_topics -->
and
block_recent_topic_wide.html
	<div style="width:100%; overflow:visible;">
		<table width="100%" cellpadding="1" cellspacing="1">
				<!-- IF scrollwide.recent_topic_row.S_ROW_COUNT == 0 -->
					<td width="auto">{L_TITLE}</td>
					<td width="auto">{L_POSTER}</td>
					<td align="right" width="auto">{L_POSTED}/{L_EDITED}</td>
				<tr><td colspan="3"><hr /></td></tr>
				<!-- IF scrollwide.recent_topic_row.S_UNIQUE -->
					<tr class="bg3"><td colspan="3" width="auto" style="text-align:left;"><strong><a href="{scrollwide.recent_topic_row.U_FORUM}">{scrollwide.recent_topic_row.S_FORUM}</a></strong></td><!--<td style="text-align:right;">{L_FORUM}</td>--></tr>
				<!-- IF scrollwide.recent_topic_row.S_ROW_COUNT is even --><tr class="bg2"><!-- ELSE --><tr class="bg1"><!-- ENDIF -->
				<td width="auto">{scrollwide.recent_topic_row.LAST_POST_IMG} <a href="{scrollwide.recent_topic_row.U_TITLE}" >
				<span class="<!-- IF scrollwide.recent_topic_row.S_TYPE == 2 or scrollwide.recent_topic_row.S_TYPE == 3 -->red<!-- ELSEIF scrollwide.recent_topic_row.S_TYPE == 4 or scrollwide.recent_topic_row.S_TYPE == 5 -->orange<!-- ELSEIF scrollwide.recent_topic_row.S_TYPE == 1 -->green<!-- ELSE --><!-- ENDIF -->">{scrollwide.recent_topic_row.S_TITLE}</span></a>:
				<td width="auto">{scrollwide.recent_topic_row.S_POSTER} </td>
				<td align="right" width="auto">{scrollwide.recent_topic_row.S_POSTTIME}</td>
				<table width="100%" cellpadding="0" cellspacing="0">
					<td class="bg3" style="padding:3px;" align="left" width="auto"><b>Legend:</b><span class="red"> Announcements</span>, <span class="green"> Sticky</span>, <span class="orange"> News</span> and <b> Normal</b> posts.</td>
					<td class="bg3" style="padding:3px;" align="right" width="auto"><b>{SEARCH_TYPE}, {SEARCH_LIMIT}</b></td>
			</td></tr>
				<!-- IF staticwide.recent_topic_row.S_ROW_COUNT == 0 -->
				<!-- IF staticwide.recent_topic_row.S_UNIQUE -->
					<tr class="bg3"><td colspan="3" width="auto" style="text-align:left;"><strong><a href="{staticwide.recent_topic_row.U_FORUM}">{staticwide.recent_topic_row.S_FORUM}</a></strong></td><!--<td style="text-align:right;">{L_FORUM}</td>--></tr>
				<!-- IF staticwide.recent_topic_row.S_ROW_COUNT is even --><tr class="bg2"><!-- ELSE --><tr class="bg1"><!-- ENDIF -->
				<td width="auto">{staticwide.recent_topic_row.LAST_POST_IMG} <a href="{staticwide.recent_topic_row.U_TITLE}" >
				<span class="<!-- IF staticwide.recent_topic_row.S_TYPE == 2 or staticwide.recent_topic_row.S_TYPE == 3 -->red<!-- ELSEIF staticwide.recent_topic_row.S_TYPE == 4 or staticwide.recent_topic_row.S_TYPE == 5 -->orange<!-- ELSEIF staticwide.recent_topic_row.S_TYPE == 1 -->green<!-- ELSE --><!-- ENDIF -->">{staticwide.recent_topic_row.S_TITLE}</span></a>:
				<td width="auto">{staticwide.recent_topic_row.S_POSTER} </td>
				<td align="right" width="auto">{staticwide.recent_topic_row.S_POSTTIME}</td>
					<td class="bg3" style="padding:3px;" align="left" width="auto"><b>{SEARCH_TYPE}, {SEARCH_LIMIT}</b></td>
					<td class="bg3" style="padding:3px;" align="right" width="auto"><b>Title Legend:</b><span class="red"> Announcements</span>, <span class="green"> Sticky</span>, <span class="orange"> News</span><b> Normal</b></td>
			</td></tr>
</span>
Peter
DragonMaster
Thank you MUCH!!!
I will install that as soon as I have a few minutes and advise here
Again...THANK YOU!!!
bc2005
Post by bc2005 »
Is it possible for Board3 Portal users to add a scrolling recent topics block?
Kind regards,
Hans
helwoe
Post by helwoe »
I'm interested in this as well. How do you add that code into a prosilver based theme?
helwoe
sp0k
phpBB.com User: sp0k
Post by sp0k »
hello any new news on this one.....i would like to use this
