Moving Things Around?
NewEditionFanClub
phpBB.com User: candysmall
Post by NewEditionFanClub »
Your Portal Version: 1.0.3
Boardlink: http://www.neweditionfanclub.com/board
Nothing
Nothing
I don't understand how I move the blocks around to different spots. I only see in the ACP to activate or deactivate things.
NewEditionFanClub
Re: Moving Things Around?
Update... I looked in the modules and I see them enabled under Portal but my left column shows none of them.
NewEditionFanClub
Thanks for that. Why don't I see anything in the left column in the ACP even after refreshing and purging? See here:
Please don't shout at me. ;)
If purging cache and refreshing styles don't get you further, try to add the modules manually in the ACP.
NewEditionFanClub
Kevin wrote:Please don't shout at me. ;)
Sorry, I didn't shout... I was typing it bigger so you could see the typing above the picture. Yes, I went in and looked at the modules. They are all there... but I'm not seeing them when I click on the portal tab. See this:
It seems that your modules are not in the ".mod" container, as is see "ACP --> Portal" on your screenshot.
It should be in ACP --> .mods --> Portal"
Have you already added them manually?
As long as you are not sure how to add them: I think the easiest way is to remove those portal modules, uninstall the portal with our installer and reinstall it afterwards. The modules should be there then.
NewEditionFanClub
All set! Thanks so much!
