Your Portal Version: 1.0.3
Boardlink: localhost
I do not have live phpbb3 yet , all my work is still in personal server.
I was have 1.0.2 and it works fine in my localhost. When ver. 1.0.3 came, I decided to update, I update everything but when I finished and went to install folder to update the database, white blank page came.
I thought it was from the language files , so I put the original one ( english ), nothing happened.
So I decieded to install fresh phpbb3 in new directory and new database, and i did new installation for the portal 1.0.3 and after modifications all the files and putting the including files to their right paths and went to install folder again a white balnk page came.
So now I can't did any installtion and my new phpbb3 gives an error ( when I delete the install folder ) telling that the table of the portal_config is not found.
This my problem , and I checked many times my modifiactions.
also i called directly some files in the install folder ( which are install_install.php, index.php, install_update.php )
all give me white blank page.
I tried to add the install folder of the ver 1.0.2 it works.
so why the installtion of the ver 1.0.3 dosent work???
Thank you
Can't install or update
Re: Can't install or update
may this help you,
I went to the php error logs and I see this error
and that line is
which is loacted in these lines
Note: the PhP is 5
[02-Apr-2009 18:17:31] PHP Fatal error: Non-static method module::get_tables() cannot be called statically in C:\apache2triad\htdocs\commGB\install\index.php on line 148Code: Select all
$tables = get_tables($db);Code: Select all
// Check if the board3 Portal is already installed and acp_parent_module is already exists
if (in_array(PORTAL_CONFIG_TABLE, $tables))
