Problem on Portal.php
It looks as if my right sidebar is gone and they are all centered now. I'm not sure how this happend. Can anyone help?
Brandon
Brandon
Re: Problem on Portal.php
The latest version of board3 portal is 1.0.3 so I suggest you download and install that version and that will remove all the bugs encountered since 1.0.0RC3 and at the same time add some new features to your portal.
Oh sorry, I forgot to select that. I have the lastest.
A link to your board would be helpful.
Yeah as you can see, the only block that is almost correct is the global message there. Like the login block and everything else has been pushed to the bottom and centered. Even the paypal block has been centered and I have the "small block" enabled in the acp.
I have the same problem. However, if I disable the "News" block, everything goes back to normal. Everything was fine until I posted for the first time in my new forum. I don't want to have "News" disabled though and hope we could get some solutions.
Here is my site
http://www.untamedgaming.com/
Here is my site
Have you done changes to the portal_body.html?
Try replacing it with a original one. Dont forget to purge the cache afterwards.
I had not made any changes to the portal_body and I also replaced it just in case and that didn't work.
I think the problem is if you have no news/posts to display in that block, it won't show up in normal format. I made a test post in one of my forums and it showed up on the portal like it should. I guess the solution is to always have at least 1 post made.
subsilver2 based styles?
Please try adding these changes: http://board3deportal.svn.sourceforge.n ... vision=499
This was a bug in news_compact.html and news_announcement.html... Make any Postings in your Board, or do the changes as you can see if you follw Kevins Link, and it will work again
@Kevin: seltsam ist aber, das eigentlich der announcement Bock ausgeblendet sein sollte wenn keine vorhanden sind, (seit der 1.0.3) was er aber bei ihm nicht ist...
Thank you, kevin! Applying the fixes from the link you supplied worked a charm.
I really appreciate the help.
http://www.weareparadox.com
Also one more thing, sorry for double post. If you look at the board index, some forums have "No new posts" above the text. And then other forums have the "No new posts" right beside it. I would like if they could all be on top. I'm not sure what would cause this weird behavior.
If i look at your Board index, i dont see any Forum but:Brandonjjon wrote:If you look at the board index, some forums have "No new posts" above the text.
This board has no forums.
