Custom styles with this mod.
Moderator: Dyo
Kuxor
Post by Kuxor »
I want to install this mod to my forum, however, i'm currently using the style acidtech red on my forum. The installation instructions do not work for this style (becuase the files are different from prosilver). Could someone please help me with installing this on acidtech red (i'm a beginner with web stuff so dont have a clue what to do/ where to start :D)
Thanks,
Kruxor :)
MrBaseball34
phpBB.de User: MB34
Re: Custom styles with this mod.
Post by MrBaseball34 »
AcidTech is based on subsilver2, you need to do the edits that are contained in the subsilver2.xml install file.
Do you have your board set up on a development machine? If you do, make a copy of it, then rename the
install.xml to prosilver.xml and rename the subsilver2.xml to install.xml then install using AutoMod.
If you still have problems, open the just renamed subsilver2.xml file in IE and follow the instructions.
I am having a few problems getting it installed on my subsilver2-based style but am currently working on
getting it correct. I will install the acidtech-red and see if I can get it working later this evening.
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
Kuxor
Post by Kuxor »
cheers, will try this out and tell you if it works after :)
Maybe you need a working config for your Blocks, since the one from subsilver looks ugly on this Style...
You can find it here: viewtopic.php?f=42&t=2083 (and some other configs...)
