Portal Blocks missing
Moderator: Dyo
Kuxor
Post by Kuxor »
Yes, this is my 3rd post in 2 days, i'm still learning ^^
Basically i've installed this mod onto my forum and along the left side the headers have no colour (they should be red) and on the board index there are no side blocks (except the birthdays one on the left :S) at all.
If you dont understand my poor explaination heres a link to my forum: http://warcry.gamingalliance.co.uk
Anyone know what i've done wrong here, the help would be much appreciated ^^
Thanks,
Kuxor
Re: Portal Blocks missing
You have to include the _block_config.html into the Header...
(damn... this portalviewMod really needs an Update :x )
Kuxor
Post by Kuxor »
just so i dont do it wrong (it'd be just my luck :P) how would i go about doing so :)?
open your styles/acidtechred/template/overall_header.html
find:
<!--version $Id: portal_body.html 347 2008-08-29 20:26:42Z kevin74 $ //-->
add after:
<!-- INCLUDE portal/_block_config.html -->
Please tell me if it works or not ;)
Kuxor
Post by Kuxor »
awesome, it worked :) looks normal now ^^ cheers for the help
only thing still wrong is the side bars on the actual forum itself (not the portal page) only the birthdays one is there, have i missed doing something in the installation :?
Kuxor
Post by Kuxor »
still not sure what i did wrong in that, went back through the instructions and cant see anything i missed, i was using the subsilver2 installation and have seen that others have had problems with that aswell, anything that was missed from the instructions?
