Boardlink: http://www.ingenerality.byethost16.com/forum
PHP Version: 3.0.4
I've tried all of the instructions.
I'm looking for someone to help me install the Board3 portal to my site. I have no knowledge of how to install it. If you can help, please add me or e-mail me at austin1197@hotmail.com , or PM me. Thank you!
Need Someone To Install Portal
- Valued Contributor
- phpBB.de User: MB34
Re: Need Someone To Install Portal
You should use the instructions for the subsilver2 style as said in this post by the Hermes style author:
http://www.stsoftware.biz/support/viewt ... rmes#p2178
If you don't know how to do that, let me know and I'll try to help you.
MrBaseball34
Hook 'em Horns
2005 College Football National Champions
2005 College Baseball National Champions
Hook 'em Horns
same problem.
after visitning the site, i still got no ideas how should i install the portal.
anyone can help me?
donnyeo81@gmail.com
grateful for reading.
anyone can help me?
donnyeo81@gmail.com
You know I tried to help but you wouldn't/couldn't communicate with me via email. You insisted on using PM on this board,. I requested that you contact me via EMAIL. If you can't follow those simple instructions, it's no wonder you can't get your portal installed.
Good luck...
Good luck...
MrBaseball34
Hook 'em Horns
Hook 'em Horns
Me? i dont remember i PM you.MrBaseball34 wrote:You know I tried to help but you wouldn't/couldn't communicate with me via email. You insisted on using PM on this board,. I requested that you contact me via EMAIL. If you can't follow those simple instructions, it's no wonder you can't get your portal installed.
Good luck...
nevertheless, i am not able to send you an email via the board. guess my access level is not enough.
kind enough to provide me with your email?
