Call to member function sql_query() on a non-object
thepips
phpBB.com User: thepips
Post by thepips »
I'm trying to develop my own block to allow the user to update their location for a weather forecast but I'm getting this error whenever I click submit.
Here's the code for the php action which is where I'm getting the error
global $phpbb_root_path, $phpEx, $user, $db, $config, $cache, $template;
 * @author Action Replay
 * @copyright 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : '../../';
$theuser = $_POST['theuser'];
$thelocation = $_POST['location'];
	if ($theuser != ANONYMOUS)
		//Get the custom profile field for this user
		$sql = 'UPDATE PROFILE_FIELDS_DATA
				SET pf_location = ' . $thelocation
			 	. ' WHERE user_id = ' . (int) $theuser;
return($result);
For completeness this is the code for the block
	function clean_location($location)
		//If the location is empty, generate a random location
		if (empty($location))
			 * We will select a random location and return it
			 * @return string mixed $location
			$location = random_location();
		$location = strip_tags($location, '');
		$search = array('%', ' ');
		$replace = array('', ',');
		$location = str_replace($search, $replace, $location, $count);
		return $location;
	function random_location()
		global $user, $auth;
			$l_array = array(
				'Basingstoke',
				'Cardiff',
				'Leeds',
				'Birmingham',
				'Manchester',
				'Southampton',
				'London',
			$nlocation = $l_array[array_rand($l_array, 1)];
			$location = request_var('location', $nlocation);
		return $location;
	if (!defined('IN_PHPBB'))
           exit;
    if (!defined('IN_PORTAL'))
           exit;
	$userid_weather = $user->data['user_id'];
	if ($userid_weather > 1)
		$display_menu = true;
		$display_menu = false;
// If the user is logged in
		if ($userid_weather != ANONYMOUS)
			$location = request_var('location', '');
//			$user->get_profile_fields($user->data['user_id']);
			//If they have a location set, use it
			if (!empty($user->profile_fields['pf_location']))
			   	$location = $user->profile_fields['pf_location'];
				 * We are cleaning any unwanted data out of the string
				 * @var string mixed
				$location = clean_location($location);
				$location = random_location();				/**
				 * @var string mixed
			 * This is where the action starts
			 * @var $location string mixed
//			build_weather::get_weather($location);
		// If not logged in, use the default or let them check their weather via URL
		elseif ($userid_weather == ANONYMOUS && !$auth->acl_get('u_weather'))
			 * @var string mixed
	$template->assign_vars(array(
                'WEATHER_LOC'     => (!empty($location)) ? $location : '',
                'USERID_WEATHER' => $userid_weather,
                'SHOW_SEARCH' => $display_menu,
				'U_UPDATE_LOCATION'		=> append_sid("{$phpbb_root_path}portal/includes/update_location.$phpEx"),
And finally the code for the html
{$LR_BLOCK_H_L}<img src="{T_THEME_PATH}/images/portal/portal_weather.png" width="16px" height="16px" alt=""/>&nbsp;Weather{$LR_BLOCK_H_R}
<div class="portal-panel">
	<div class="inner">
				<!-- IF SHOW_SEARCH -->
				<form method="post" id="forecast" action="{U_UPDATE_LOCATION}">
					<input type="hidden"
						name="theuser"
						value="{USERID_WEATHER}"
					<input type="text"
						tabindex="6"
						name="location"
						id="searchfield"
						size="22"
						maxlength="40"
						title="Enter town or postcode"
						class="inputbox search"
						value="{WEATHER_LOC}"
						onclick="if(this.value=='Weather')this.value='{WEATHER_LOC}';"
					<fieldset class="submit-buttons">
					<input type="reset"
						value="{L_RESET}"
						name="reset"
						class="button2" />
					<input type="submit"
						name="action"
						value="{L_SUBMIT}"
						class="button1" />{S_FORM_TOKEN}
					</fieldset>
				</form></p><!-- ENDIF -->
<!-Weather in {WEATHER_LOC}, UK on your site - HTML code - weatherforecastmap.com --><div align="center"><script src="http://www.weatherforecastmap.com/weather3.php?zona=england_{WEATHER_LOC}"></script><a alt="Weather Today in {WEATHER_LOC}" title="Weather Today in {WEATHER_LOC}" href="http://www.weatherforecastmap.com/england/{WEATHER_LOC}" target='_blank'>Weather Today in {WEATHER_LOC}</a></div><!-end of code-->	<span class="portal-corners-bottom"><span></span></span>
<br style="clear:both" />
Can anyone shed any light on what I'm doing wrong?
Regards
Doug
