Well my problem is that i have double days...im having the alighter calendar 1.0.0
after having dealt with a duplicate error of if defind in minical.. (went nuts and commented all the checks for it out and it didnt show) but now im having duplicate entry of the calendar..
you can see it here http://area51.svosiris.com/phpBB3/gallery/index.php
on the portal is shows correctly...
Does anybody have a solution
having troubles with mini calendar
Moderator: Dyo
Rotsblok
Rotsblok
Re: having troubles with mini calendar
Nevermind I solved it.. although its kinda hard to tell what I have done, as it involved some code changes...
