Your Portal Version: 1.0.4
Your phpBB Type: phpBB3 with many MODs
PHP Version: 3.0.5
I have install the portal while ago, and now I realized that it doesn't appear in ACP to change some configuration.
I have made an update with the last 1.0.4. And it doesn't appear too. And I don't know why.
I don't know what I miss... Maybe the install has not install nothing in adm folder.
best regards
EDIT: SOLVED!
Portal is allright but doesn't appear in ACP
Leinad4Mind
- phpBB.de User: Leinad4Mind
- phpBB.com User: Leinad4Mind
Re: Portal is allright but doesn't appear in ACP
I have the same issue.
any insight from anyone?
