das ist mein Style
http://www.hjmcomputer.de/forum/
a mixed from subsilver2 and AeroBluehttp://www.phpbbhq.com/
Das ist meine overall_header.html
<head>
{META}
<!-- IF S_ENABLE_FEEDS -->
<link rel="alternate" type="application/atom+xml" title="{L_FEED} - {SITENAME}" href="{U_FEED}" />
<!-- IF S_ENABLE_FEEDS_TOPICS --><link rel="alternate" type="application/atom+xml" title="{L_FEED} - {L_ALL_TOPICS}" href="{U_FEED}?mode=topics" /><!-- ENDIF -->
// <![CDATA[
function hide(id) { document.getElementById(id).style.display="none"; }
function show(id) { document.getElementById(id).style.display="block"; }
function layerTest(id) {
if ( document.getElementById(id).style.display == 'none' ) {
show(id);
} else {
hide(id);
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
popup('{UA_POPUP_PM}', 480, 180, '_phpbbprivmsg');
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
popup(url, 870, 570, '_usersearch');
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
function selectCode(a)
// Get ID of code block
var e = a.parentNode.parentNode.getElementsByTagName('CODE')[0];
// Not IE
if (window.getSelection)
var s = window.getSelection();
// Safari
if (s.setBaseAndExtent)
s.setBaseAndExtent(e, 0, e, e.innerText.length - 1);
// Firefox and Opera
var r = document.createRange();
r.selectNodeContents(e);
s.removeAllRanges();
s.addRange(r);
// Some older browsers
else if (document.getSelection)
var s = document.getSelection();
s.addRange(r);
// IE
else if (document.selection)
var r = document.body.createTextRange();
r.moveToElementText(e);
r.select();
</script>
</head>
<a name="top"></a>
<table class="wrap" width="100%" cellpadding="0" cellspacing="0">
<tr><td>
<div id="wrapheader">
<td width="18" height="18"><img src="{T_THEME_PATH}/images/tl.png" width="18" height="18" alt="" /></td>
<td height="18" style="background:url('{T_THEME_PATH}/images/tm.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/tr.png" width="18" height="18" alt="" /></td>
<td width="18" style="background:url('{T_THEME_PATH}/images/ml.png');"></td>
<td>
<table width="100%" border="0" align="center" cellpadding="0" cellspacing="0">
<td width="303" height="80" style="background:url('{T_THEME_PATH}/images/midl.png');"><div class="logo"><a class="headw" href="{U_INDEX}">{SITENAME}</a><br /><span class="genmedw">{SITE_DESCRIPTION}</span></div></td>
<td height="80" style="background:url('{T_THEME_PATH}/images/midm.png');"> </td>
<td width="470" height="80" align="right" valign="top" style="background:url('{T_THEME_PATH}/images/midr.png');">
<div class="midlink">
<div id="search-box">
<fieldset class="nb">
<input name="keywords" style="opacity:0.8;filter:alpha(opacity=80)" onmouseover="this.style.opacity=1;this.filters.alpha.opacity=100" onmouseout="this.style.opacity=0.8;this.filters.alpha.opacity=80" type="text" class="inputbox search" id="keywords" title="{L_SEARCH_KEYWORDS}" onblur="if(this.value=='')this.value='{LA_SEARCH_MINI}';" onclick="if(this.value=='{LA_SEARCH_MINI}')this.value='';" value="<!-- IF SEARCH_WORDS-->{SEARCH_WORDS}<!-- ELSE -->{L_SEARCH_MINI}<!-- ENDIF -->" maxlength="50" />
<input class="nb" name="submit" type="image" src="{T_THEME_PATH}/images/search.png" align="absmiddle" /><br />
<a class="genmedw" href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}">{L_SEARCH_ADV}</a> {S_SEARCH_HIDDEN_FIELDS}
</fieldset>
</form>
<td height="24" align="left" style="background:url('{T_THEME_PATH}/images/bottomm.png');">
<div class="buttonwrapper">
<div class="navspacel"></div>
<!-- IF S_USER_LOGGED_IN -->
<!-- ELSEIF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) -->
<a class="squarebuttonl" href="{U_REGISTER}"><span>{L_REGISTER}</span></a><div class="navspacel"></div>
<a class="squarebuttonl" href="{U_PROFILE}"><span>{L_PROFILE}</span></a><div class="navspacel"></div>
<!-- IF S_DISPLAY_PM -->
<a class="squarebuttonl" href="{U_PRIVATEMSGS}"><span>{PRIVATE_MESSAGE_INFO}</span></a><div class="navspacel"></div>
<a class="squarebuttonl" href="{U_RESTORE_PERMISSIONS}"><span>{L_RESTORE_PERMISSIONS}</span></a>
<!-- IF U_PORTAL -->
<a class="squarebuttonl" href="{U_PORTAL}"><span>{L_PORTAL}</span></a>
<a class="squarebuttonl" href="{U_INDEX}"><span>{L_INDEX}</span></a>
<td width="431" height="24" align="right" style="background:url('{T_THEME_PATH}/images/bottomr.png');">
<div class="navspacer"></div>
<!-- IF not S_IS_BOT -->
<a class="squarebuttonr" href="{U_LOGIN_LOGOUT}"><span>{L_LOGIN_LOGOUT}</span></a><div class="navspacer"></div>
<a class="squarebuttonr" href="{U_MEMBERLIST}"><span>{L_MEMBERLIST}</span></a><div class="navspacer"></div>
<a class="squarebuttonr" href="{U_FAQ}"><span>{L_FAQ}</span></a>
<td width="18" style="background:url('{T_THEME_PATH}/images/mr.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/bl.png" width="18" height="18" alt="" /></td>
<td height="18" style="background:url('{T_THEME_PATH}/images/bm.png');"></td>
<td width="18" height="18"><img src="{T_THEME_PATH}/images/br.png" width="18" height="18" alt="" /></td>
<div id="datebar">
<!-- IF S_BOARD_DISABLED -->
<tr><td class="gensmall">
<span class="error">{L_BOARD_DISABLED}</span>
</td></tr>
<!-- IF S_DISPLAY_SEARCH -->
<p class="searchbar">
<span style="float: {S_CONTENT_FLOW_END};"><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a> | <a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></span>
</p>
<br style="clear: both;" />
<div class="bc">
<table class="bcbg" width="100%" cellspacing="1" cellpadding="0" style="margin-top: 5px;">
<td class="row1">
<p class="breadcrumbs"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}">{L_INDEX}</a><!-- BEGIN navlinks --> » <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></p>
<p class="datetime">{S_TIMEZONE}</p>
