The problem was immediately there after installing the portal.
Yes I have, but I have no good idea of where to search in the files :S
I have the Maxthon theme installed. Which had the same templates as prosilver but other theme and template.
So I already edited the stylesheet of Maxthon and added the image set. That works fine because I see the images and all on the portal (as you can see on the images).
So every thing works fine except one thing. All list where a bullet dot can be found is wrong positioned.
Because my English is really bad i'll add some pics in order to clear things up.
Could somebody please help me out? :S
