Wordgraph - how to exclude words
Your Portal Version: 1.0.5
Boardlink: http://www.borovnica.eu
Nothing
Edit "search_ignore_words.php"
Hello guys,
My Wordgraph show most common words, but those words are so common, that search engine wont except them.
I wish to exclude words, as "we", "a", "they", ... and others. So Wordgraph will show really important most common words, as "borovnica" and others...
Search engine in PHP have list of exclude words, which is good start to exclude this words.
Is there any similar list for Wordgraph ?
Any other solution ?
Nothing
Hello guys,
Re: Wordgraph - how to exclude words
Hi urednik,
did you -by any chance- manage to create a filter for wordgraph?
If so, please share the code?
Would be awesome, because lot's of 3-letter words are indeed too common for wordgraph to be practical.
I just increase number of letters for words, to exclude words with les then to 5 letters.
Ah ok thanks.
Will look into this tonight
To exclude common words (see ACP ? Search settings ? Common word threshold):
find in portal/block/wordgraph.phpadd after
To exclude common words and words contained in search_ignore_words.php
find in portal/block/wordgraph.phpreplace with
FROM ' . SEARCH_WORDLIST_TABLE . 'Code: Select all
WHERE word_common <> 1find in portal/block/wordgraph.php
$sql = 'SELECT word_text, word_count, word_id
GROUP BY word_id, word_text
ORDER BY word_count DESC'; Code: Select all
include($phpbb_root_path . 'language/' . $config['default_lang'] . '/search_ignore_words.' . $phpEx);
$sql = "SELECT word_text, word_count, word_id
FROM " . SEARCH_WORDLIST_TABLE . "
AND word_text NOT IN ('" . implode('\', \'', $words) . "')
ORDER BY word_count DESC";Re: Wordgraph - how to exclude words
THNX !!!
It works!
Maybe this is also good to include into next version of Board 3 Portal ...
THNX again !!
It works!
THNX again !!
Thank you Nekstati!
Treverer
- phpBB.de User: Treverer
- phpBB.com User: Treverer
first: hi at allurednik wrote:I just increase number of letters for words, to exclude words with les then to 5 letters.
your advise did not work in my wordgraph. perhaps the list of words are not updated, but i tried much (not everything
so use this solution, without Nekstati exclude list firtst:
find
WHERE LENGTH(word_text)>'.(int) $config['fulltext_native_min_chars'].'
you need an sql-database, which nows sql-order 'length' - mysql did
so, and now i will work for a solution which integrates Nekstati exclusion word list...
Treverer
so, here my solution combided with yours:Nekstati wrote:To exclude common words (see ACP ? Search settings ? Common word threshold):
find in portal/block/wordgraph.phpadd afterCode: Select all
FROM ' . SEARCH_WORDLIST_TABLE . 'To exclude common words and words contained in search_ignore_words.phpCode: Select all
find in portal/block/wordgraph.phpreplace withCode: Select all
$sql = 'SELECT word_text, word_count, word_id FROM ' . SEARCH_WORDLIST_TABLE . ' GROUP BY word_id, word_text ORDER BY word_count DESC';Code: Select all
include($phpbb_root_path . 'language/' . $config['default_lang'] . '/search_ignore_words.' . $phpEx); $sql = "SELECT word_text, word_count, word_id FROM " . SEARCH_WORDLIST_TABLE . " WHERE word_common <> 1 AND word_text NOT IN ('" . implode('\', \'', $words) . "') GROUP BY word_id, word_text ORDER BY word_count DESC";
it's only the one entry "AND LENGTH(word_text)>".(int) $config['fulltext_native_min_chars'].", but is better now i think...
hm, in 1.0.6 the wordgraph code changed obviously. Do you know what lines to change there?
