The mod link: viewtopic.php?f=21 ... f0c48014e3
Using the latest version of this block (2.2.0) with the latest PHPBB version (3.07-PL) and the latest Board3 (1.0.5), I am getting a pretty serious error that makes it so I really can't use this block.
What happens is, when logging in as admin (from guest), and then trying to access the ACP, an error occurs, not allowing access to the ACP.
The error is as follows : Fatal error: Class 'template_compile' not found in /home/site/public_html/forum/includes/template.php on line 314
Sometimes, after several refreshes, it goes through, and takes me to the screen that asks me to re-type in my admin password, this page is white, theme-less and has no graphics... looks all glitchy, etc. I can eventually reach the ACP after a few more refreshes.
I have narrowed this issue right to this mod, as using a fresh install of phpbb and installing it causes the problem, and then uninstalling it fixes the problem. The mod works fine with the previous version of phpbb, so I assume it's 3.07 not being compatible with the installer for the mod, since it does database changes. Can someone take a look at the installer and see if they can update it?
WoW Progress Block for Board3 - FIX request
1 post
• Page 1 of 1
emjh
Post by emjh »
1 post
• Page 1 of 1
Jump to
- Portal
- ↳ Board3 Portal Releases / Download
- ↳ F.A.Qs
- ↳ Board3 Portal 2.3.x - Deutscher Support
- ↳ Board3 Portal 2.3.x - English Support
- ↳ Show-Off
- board3 Styles
- ↳ Styles Support
- ↳ Released styles
- ↳ v2.1.x
- ↳ Style requests
- Modification Dev
- ↳ Released Modifications
- ↳ v2.3.x
- ↳ v2.1.x
- ↳ Modification Requests
- ↳ Modifications - In Development
- ↳ v2.3.x
- ↳ v2.1.x
- ↳ Modifications Support
- International
- ↳ Completed Translations
- ↳ Translations in Development
- Board3.de
- ↳ Board3.de
- ↳ Small talk
- ↳ Trash bin / Papierkorb
- Archive
- ↳ KB-Archiv
- ↳ Forum-Archive
- ↳ Board3 Portal 2.1.x - Deutscher Support
- ↳ Board3 Portal 2.1.x - English Support
- ↳ board3 Portal 2.0.x Archive
- ↳ Board3 Portal 2.0.x - Deutscher Support
- ↳ Board3 Portal 2.0.x - English Support
- ↳ Released Styled v2.0.0b1 / v2.0.0 / v2.0.1 / v2.0.2
- ↳ Released Modifications v2.0.x
- ↳ Modifications - In Development v2.0.x
- ↳ v2.0.2
- ↳ v2.0.1
- ↳ v2.0.0
- ↳ v2.0.0b1
- ↳ Released configs
- ↳ Config requests
- ↳ v2.0.0b1 / v2.0.0 / v2.0.1 / v2.0.2
- ↳ board3 Portal 1.0.x Archive
- ↳ board3 Portal 1.0.x - Deutscher Support
- ↳ board3 Portal 1.0.x - English Support
- ↳ board3 Portal v1.0.4 / v1.0.5 / v1.0.6 - Styles
- ↳ board3 Portal v1.0.4 / v1.0.5 / v1.0.6 - Configs
- ↳ board3 Portal v1.0.x - Modifications
- ↳ board3 Portal v1.0.6 - Translations
- ↳ board3 Portal Translations for earlier Versions (< 1.0.6)
- ↳ board3 Portal v1.0.x - Modifications in Dev
- ↳ MOD Portalview - Portal blocks in whole forum
- ↳ General phpBB3 Support
- ↳ phpBB3 Portal
- ↳ Informationen zu Olympus
