I can not edit the mod
Hi, I am new to this topic phpbb3 e installed on my Web site, but now I have a problem and I can not see any panel editing phpbb3 portal to be able to edit the parameters of the portal.
What can be the solution?
- phpBB.de User: thomas.d
- phpBB.com User: thomas.d
Re: I can not edit the mod
Look in your ACP.
It should have a new tab "MODS" on the right hand side of "SYSTEM".
Look about like this:
![Image](http://img186.imageshack.us/img186/946/image1uk5.png)
Thomas
Deutsche Sprachdateien für
ACP Add User MOD 1.0.0 |
Thomas
That is the problem, I have no new tab, the last is "system"
Still, the site is working properly.
http://www.yolje.com/public/phpbb3/portal.php
This is not Board3 portal but the phpbb3 portal
<!--// phpBB3 Portal by Sevdin Filiz, www.phpbb3portal.com //-->
Walter
Walter
Thank you for the information and please disculpad error.
I have problems to move in this forum because of the language, so I would like to ask if it is not too much trouble, can where there are links to download board3 portal stable?
Wish I could try.
Thank you again and apologize.
Wish I could try.
Walter
Walter
Nevermind ...chechu wrote:Thank you for the information and please disculpad error.
Wish I could try.
The download link for this portal here ("board3 portal") you will find here: viewtopic.php?f=10&t=183
Please note, that this release is still in beta-state. On the other hand a considerable amount of users runs it on live boards with no problems.
Thomas
Thomas
Thank you thomas.d then, there is no stable version of board3 portal? Another question, I use style etech in pbpbb3, what could be done to use with this style?
Hi chechu,
if you mean "stable" like at least a release candidate ... well, it's beta ...
If you mean "stable" like from "not crashing" to "running fine", this one is for you.
Questions about style-matters will be answered by Christian_N, as he's the "Style Doctor". I'm sure he will soon take care of your question.
Thomas
Thomas
Hi chechu,
You should know that in the download of the Board3 portal there are also upgrades provided from phpBB3 portal releases to the latest Board3 portal.
Good luck.![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
Good luck.
Thank you, thomas.d, attempts to contact Christian_N or see how I get on board3 style etech.
Pado, so I could understand the translator of google, what I say is that it will soon be improvements in board3 right? Sorry, it is not well understood the translation.
I did not understand whether there will be improvements in board3 or phpbb3 portal… thousand apologies.
Many thanks to both for care.
Yes, there will be improvements and new features in the next release of Board3 portal.
Don't know when, but I hope soon.
In the mean time you could use the actual release without many risks, because this (beta) version is pretty stable.
The developments in Board3 and in phpBB3 portal are completely independent from each other. (Correct me , if I am wrong, Kevin).
Does that answer your questions?
Hi I just install the portal and it looks great The only problem is that I can't get into change the portal , In ACP under .mods when I click on the tab I get this error
General Error
Module not accessible.
I enabled it and still the same I cleared cookies and cleared cache in ACP and I cleared temp files cookies and history files in computer still the same.
Could you Please tell me what I am doing wrong. I would like to get this to work so I can upload it to my site,
I thank You for the portal and any help that you might give
I solved the problem.
I just moved the portal from .mods to General tab.
Now the portal settings shows up in General tab.
Sorry for the post
General Error
Sorry for the post
