Your Portal Version: 1.0.5
PHP Version: 3.0.7-PL1
I installed phpBB 3.0.7-PL1 the other day. I got everything working with this version, set up my forums, config settinging, etc. Then tried to install Board3 1.0.5. I followed all the instructions in the xml file. The installation (seemingly) went ok; I got a page saying to please delete the Install folder. Before doing so, I tried to get into the ACP. Got the error "The service is unavailable." So I deleted the Install folder. I was able to get into the board and forums, but still the same error on the ACP.
I decided to try to get back to what I had before trying to attemt the mod. I deleted the Forum folder (root), then uploaded my backup from my local machine. Same problem... I get the "The service is unavailable." error.
So, then I went into the database and deleted the one table that is added by the mod. Still didn't work. Then I tried to just re-install the mod anyway to see if that fixes the problem. Didn't work.
I have no idea what''s wrong. I would like to get this mod working, but if I can't, I would at least like to get my board back to the way it was before.
Any ideas?
Thanks in advance!
						Trouble installing.. then removing
Re: Trouble installing.. then removing
I have never seen such an error message. Try asking on phpBB.com if they ever came across that error message and if they know what could be wrong.
You said the error stayed there even after you uploaded the backed up files, have you tried restoring a database backup?
Unfortunately, I didn't make a database backup. I thought that the only change that this mod made was to add a table. I thought that would be easy enough to delete myself.Marc wrote: You said the error stayed there even after you uploaded the backed up files, have you tried restoring a database backup?
What other updates are made to the database during installation?
For anyone else that is having this problem, I asked my question on phpBB.com and got the board back to where it was before the mod.
THE ANSWER
For the record, I think my original problem was the fact that my cache, files and store folders permissions were not set to 777. Will try it now and see if it works.
Many thanks for the help!
						THE ANSWER
