overall_header.html error
gisfreak
phpBB.com User: gisfreak
Post by gisfreak »
Your Portal Version: 1.0.5
-advertising management 1.0.9
-adaptive hide bb code 1.0.2
just installing the latest portal and when i just finish it and delete the install folder, refresh then , BAM, error show up
just looking and review the overall_header.html, but i dont know whats wrong since my edit seems right
i try install the latest portal , and i stuck in this messages after installation
Parse error: syntax error, unexpected '}' in C:\xampp\htdocs\phpBB3\cache\tpl_rockn-roll_overall_header.html.php on line 133
oh yeah, and i use custom template , rock n roll, but as i see in detail, it seems it use prosilver as a base template
any clue on this, thanx for your help
regards, GISfreak
Re: overall_header.html error
I need a link to your board in order to see if I can find the error.
gisfreak
Post by gisfreak »
Marc wrote:I need a link to your board in order to see if I can find the error.
sorry, i usually using localhost before add this mod to my real forum, to make sure my forum will always up ;)
so in this case, the problem is arise in my phpbb that installed in localhost, i use Xampp 1.7.3 in my windows xp sp 3 to emulate this :lol:
but usually, if i get screw in my localhost, it will act same in my hosting :roll:
any other way, maybe upload the file ?, :?
Yes, please upload your overall_header.html.
gisfreak
Post by gisfreak »
here you go
http://rapidshare.com/files/387698172/overall_header.zip.html
this is overall header that located under style>rockn_roll>template>overall_header.html
since my template is rock n roll base on prosilver theme
oh yeah, before portal, i have edit those file with advertising management mod version 1.0.9
regards, GISfreak
gisfreak
Post by gisfreak »
this is the link to my themes in case you may need it
http://www.phpbb.com/customise/db/style/rockn_roll/
regards, GISfreak
gisfreak
Post by gisfreak »
hum, i post the overall_header.html for more easy
<head>
{META}
<!-- IF S_ENABLE_FEEDS -->
	phpBB style name: Rock'n Roll
	Based on style:   prosilver (this is the default phpBB3 style)
	Modified by:	Vinny ( http://www.phpbbportugal.com/ )
// <![CDATA[
	var on_page = '{ON_PAGE}';
	var per_page = '{PER_PAGE}';
	<!-- IF S_USER_PM_POPUP -->
		if ({S_NEW_PM})
			var url = '{UA_POPUP_PM}';
	* Find a member
	function find_username(url)
		return false;
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
</script>
<!-- INCLUDE ads/ads.js -->
</head>
	<div id="wrap">
	<div id="page-header">
				{ADS_1}
		<div class="forumbg">
			<div class="solidblockmenu">
		<ul>
		<li><a href="{U_INDEX}" title="{L_INDEX}">{L_INDEX}</a></li>
		<!-- IF not S_IS_BOT -->
		<!-- IF S_DISPLAY_MEMBERLIST --><li><a href="{U_MEMBERLIST}" title="{L_MEMBERLIST_EXPLAIN}">{L_MEMBERLIST}</a></li><!-- ENDIF -->
		<li><a href="{U_FAQ}" title="{L_FAQ_EXPLAIN}">{L_FAQ}</a></li>
		<!-- IF S_DISPLAY_SEARCH --><li><a href="{U_SEARCH}" title="{L_SEARCH_ADV_EXPLAIN}">{L_SEARCH}</a></li><!-- ENDIF -->
		<li><a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="e">{L_PROFILE}</a></li>
		<!-- IF S_DISPLAY_PM --><li><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a></li><!-- ENDIF -->
		<li><a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a></li>
		<li><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a></li>
		<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><li><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
				<li><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="x">{L_LOGIN_LOGOUT}</a></li>
		<div class="headerbar">
			<div id="site-description">
				<!-- <h1>{SITENAME}</h1>
				<p>{SITE_DESCRIPTION}</p> -->
				<p class="skiplink"><a href="#start_here">{L_SKIP}</a></p>
			<div id="search-box">
				<fieldset>
				</fieldset>
				</form>
				<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="return fontsizeup(event);" class="fontsize" title="{L_CHANGE_FONT_SIZE}">{L_CHANGE_FONT_SIZE}</a></li>
			<li><!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<!-- ELSE -->{CURRENT_TIME}<!-- ENDIF --></li>
				<li><!-- IF S_USER_LOGGED_IN --><!-- ELSE -->{CURRENT_TIME}<!-- ENDIF --></li>
			<!-- IF not S_USER_LOGGED_IN and not S_IS_BOT -->
	<form method="post" action="{S_LOGIN_ACTION}">
			<fieldset class="quick-login"><strong>
			<label for="username">{L_USERNAME}:</label>&nbsp;<input type="text" name="username" id="username" size="10" class="inputbox" title="{L_USERNAME}" />
			<label for="password">{L_PASSWORD}:</label>&nbsp;<input type="password" name="password" id="password" size="10" class="inputbox" title="{L_PASSWORD}" />
			<input type="submit" name="login" value="{L_LOGIN}" class="button2" />
			{S_LOGIN_REDIRECT}
		</strong></fieldset>
	</form>
	<!-- IF ADS_2 -->
	<div class="forabg">
			<ul class="topiclist">
				<li class="header">
					<dl class="icon">
						<dt>{L_ADVERTISEMENT}</dt>
					</dl>
				</li>
			<div style="padding: 5px 5px 2px 5px; font-size: 1.1em; background-color: #ECF1F3; margin: 0px auto; text-align: center;">
				{ADS_2}
	<div id="page-body">
		<div id="information" class="rules">
this is the tpl_rockn_roll_overall_header.html.php which is the error occured
<?php if (!defined('IN_PHPBB')) exit; ?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="<?php echo (isset($this->_rootref['S_CONTENT_DIRECTION'])) ? $this->_rootref['S_CONTENT_DIRECTION'] : ''; ?>" lang="<?php echo (isset($this->_rootref['S_USER_LANG'])) ? $this->_rootref['S_USER_LANG'] : ''; ?>" xml:lang="<?php echo (isset($this->_rootref['S_USER_LANG'])) ? $this->_rootref['S_USER_LANG'] : ''; ?>">
<head>
<meta http-equiv="content-type" content="text/html; charset=<?php echo (isset($this->_rootref['S_CONTENT_ENCODING'])) ? $this->_rootref['S_CONTENT_ENCODING'] : ''; ?>" />
<meta http-equiv="content-language" content="<?php echo (isset($this->_rootref['S_USER_LANG'])) ? $this->_rootref['S_USER_LANG'] : ''; ?>" />
<?php echo (isset($this->_rootref['META'])) ? $this->_rootref['META'] : ''; ?>
<title><?php echo (isset($this->_rootref['SITENAME'])) ? $this->_rootref['SITENAME'] : ''; ?> &bull; <?php if ($this->_rootref['S_IN_MCP']) {  echo ((isset($this->_rootref['L_MCP'])) ? $this->_rootref['L_MCP'] : ((isset($user->lang['MCP'])) ? $user->lang['MCP'] : '{ MCP }')); ?> &bull; <?php } else if ($this->_rootref['S_IN_UCP']) {  echo ((isset($this->_rootref['L_UCP'])) ? $this->_rootref['L_UCP'] : ((isset($user->lang['UCP'])) ? $user->lang['UCP'] : '{ UCP }')); ?> &bull; <?php } echo (isset($this->_rootref['PAGE_TITLE'])) ? $this->_rootref['PAGE_TITLE'] : ''; ?></title>
<?php if ($this->_rootref['S_ENABLE_FEEDS']) {  if ($this->_rootref['S_ENABLE_FEEDS_OVERALL']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo (isset($this->_rootref['SITENAME'])) ? $this->_rootref['SITENAME'] : ''; ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_NEWS']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FEED_NEWS'])) ? $this->_rootref['L_FEED_NEWS'] : ((isset($user->lang['FEED_NEWS'])) ? $user->lang['FEED_NEWS'] : '{ FEED_NEWS }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=news" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_FORUMS']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_ALL_FORUMS'])) ? $this->_rootref['L_ALL_FORUMS'] : ((isset($user->lang['ALL_FORUMS'])) ? $user->lang['ALL_FORUMS'] : '{ ALL_FORUMS }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=forums" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_TOPICS']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FEED_TOPICS_NEW'])) ? $this->_rootref['L_FEED_TOPICS_NEW'] : ((isset($user->lang['FEED_TOPICS_NEW'])) ? $user->lang['FEED_TOPICS_NEW'] : '{ FEED_TOPICS_NEW }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=topics" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_TOPICS_ACTIVE']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FEED_TOPICS_ACTIVE'])) ? $this->_rootref['L_FEED_TOPICS_ACTIVE'] : ((isset($user->lang['FEED_TOPICS_ACTIVE'])) ? $user->lang['FEED_TOPICS_ACTIVE'] : '{ FEED_TOPICS_ACTIVE }')); ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?mode=topics_active" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_FORUM'] && $this->_rootref['S_FORUM_ID']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_FORUM'])) ? $this->_rootref['L_FORUM'] : ((isset($user->lang['FORUM'])) ? $user->lang['FORUM'] : '{ FORUM }')); ?> - <?php echo (isset($this->_rootref['FORUM_NAME'])) ? $this->_rootref['FORUM_NAME'] : ''; ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?f=<?php echo (isset($this->_rootref['S_FORUM_ID'])) ? $this->_rootref['S_FORUM_ID'] : ''; ?>" /><?php } if ($this->_rootref['S_ENABLE_FEEDS_TOPIC'] && $this->_rootref['S_TOPIC_ID']) {  ?><link rel="alternate" type="application/atom+xml" title="<?php echo ((isset($this->_rootref['L_FEED'])) ? $this->_rootref['L_FEED'] : ((isset($user->lang['FEED'])) ? $user->lang['FEED'] : '{ FEED }')); ?> - <?php echo ((isset($this->_rootref['L_TOPIC'])) ? $this->_rootref['L_TOPIC'] : ((isset($user->lang['TOPIC'])) ? $user->lang['TOPIC'] : '{ TOPIC }')); ?> - <?php echo (isset($this->_rootref['TOPIC_TITLE'])) ? $this->_rootref['TOPIC_TITLE'] : ''; ?>" href="<?php echo (isset($this->_rootref['U_FEED'])) ? $this->_rootref['U_FEED'] : ''; ?>?f=<?php echo (isset($this->_rootref['S_FORUM_ID'])) ? $this->_rootref['S_FORUM_ID'] : ''; ?>&t=<?php echo (isset($this->_rootref['S_TOPIC_ID'])) ? $this->_rootref['S_TOPIC_ID'] : ''; ?>" /><?php } } ?>
// <![CDATA[
	var jump_page = '<?php echo ((isset($this->_rootref['LA_JUMP_PAGE'])) ? $this->_rootref['LA_JUMP_PAGE'] : ((isset($this->_rootref['L_JUMP_PAGE'])) ? addslashes($this->_rootref['L_JUMP_PAGE']) : ((isset($user->lang['JUMP_PAGE'])) ? addslashes($user->lang['JUMP_PAGE']) : '{ JUMP_PAGE }'))); ?>:';
	var on_page = '<?php echo (isset($this->_rootref['ON_PAGE'])) ? $this->_rootref['ON_PAGE'] : ''; ?>';
	var per_page = '<?php echo (isset($this->_rootref['PER_PAGE'])) ? $this->_rootref['PER_PAGE'] : ''; ?>';
	var base_url = '<?php echo (isset($this->_rootref['A_BASE_URL'])) ? $this->_rootref['A_BASE_URL'] : ''; ?>';
	var style_cookie_settings = '<?php echo (isset($this->_rootref['A_COOKIE_SETTINGS'])) ? $this->_rootref['A_COOKIE_SETTINGS'] : ''; ?>';
	<?php if ($this->_rootref['S_USER_PM_POPUP']) {  ?>
		if (<?php echo (isset($this->_rootref['S_NEW_PM'])) ? $this->_rootref['S_NEW_PM'] : ''; ?>)
			var url = '<?php echo (isset($this->_rootref['UA_POPUP_PM'])) ? $this->_rootref['UA_POPUP_PM'] : ''; ?>';
	<?php } ?>
	* Find a member
		return false;
</script>
<script type="text/javascript" src="<?php echo (isset($this->_rootref['T_TEMPLATE_PATH'])) ? $this->_rootref['T_TEMPLATE_PATH'] : ''; ?>/styleswitcher.js"></script>
<script type="text/javascript" src="<?php echo (isset($this->_rootref['T_TEMPLATE_PATH'])) ? $this->_rootref['T_TEMPLATE_PATH'] : ''; ?>/forum_fn.js"></script>
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/print.css" rel="stylesheet" type="text/css" media="print" title="printonly" />
<link href="<?php echo (isset($this->_rootref['T_STYLESHEET_LINK'])) ? $this->_rootref['T_STYLESHEET_LINK'] : ''; ?>" rel="stylesheet" type="text/css" media="screen, projection" />
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/normal.css" rel="stylesheet" type="text/css" title="A" />
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/medium.css" rel="alternate stylesheet" type="text/css" title="A+" />
<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/large.css" rel="alternate stylesheet" type="text/css" title="A++" />
<?php if ($this->_rootref['S_CONTENT_DIRECTION'] == ('rtl')) {  ?>
	<link href="<?php echo (isset($this->_rootref['T_THEME_PATH'])) ? $this->_rootref['T_THEME_PATH'] : ''; ?>/bidi.css" rel="stylesheet" type="text/css" media="screen, projection" />
<?php } $this->_tpl_include('ads/ads.js'); ?>
</head>
<body id="phpbb" class="section-<?php echo (isset($this->_rootref['SCRIPT_NAME'])) ? $this->_rootref['SCRIPT_NAME'] : ''; ?> <?php echo (isset($this->_rootref['S_CONTENT_DIRECTION'])) ? $this->_rootref['S_CONTENT_DIRECTION'] : ''; ?>">
	<div id="wrap">
				<?php echo (isset($this->_rootref['ADS_1'])) ? $this->_rootref['ADS_1'] : ''; ?>
		<ul>
		<li><a href="<?php echo (isset($this->_rootref['U_INDEX'])) ? $this->_rootref['U_INDEX'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_INDEX'])) ? $this->_rootref['L_INDEX'] : ((isset($user->lang['INDEX'])) ? $user->lang['INDEX'] : '{ INDEX }')); ?>"><?php echo ((isset($this->_rootref['L_INDEX'])) ? $this->_rootref['L_INDEX'] : ((isset($user->lang['INDEX'])) ? $user->lang['INDEX'] : '{ INDEX }')); ?></a></li>
		<?php if (! $this->_rootref['S_IS_BOT']) {  if ($this->_rootref['S_DISPLAY_MEMBERLIST']) {  ?><li><a href="<?php echo (isset($this->_rootref['U_MEMBERLIST'])) ? $this->_rootref['U_MEMBERLIST'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_MEMBERLIST_EXPLAIN'])) ? $this->_rootref['L_MEMBERLIST_EXPLAIN'] : ((isset($user->lang['MEMBERLIST_EXPLAIN'])) ? $user->lang['MEMBERLIST_EXPLAIN'] : '{ MEMBERLIST_EXPLAIN }')); ?>"><?php echo ((isset($this->_rootref['L_MEMBERLIST'])) ? $this->_rootref['L_MEMBERLIST'] : ((isset($user->lang['MEMBERLIST'])) ? $user->lang['MEMBERLIST'] : '{ MEMBERLIST }')); ?></a></li><?php } ?>
		<li><a href="<?php echo (isset($this->_rootref['U_FAQ'])) ? $this->_rootref['U_FAQ'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_FAQ_EXPLAIN'])) ? $this->_rootref['L_FAQ_EXPLAIN'] : ((isset($user->lang['FAQ_EXPLAIN'])) ? $user->lang['FAQ_EXPLAIN'] : '{ FAQ_EXPLAIN }')); ?>"><?php echo ((isset($this->_rootref['L_FAQ'])) ? $this->_rootref['L_FAQ'] : ((isset($user->lang['FAQ'])) ? $user->lang['FAQ'] : '{ FAQ }')); ?></a></li>
		<?php if ($this->_rootref['S_DISPLAY_SEARCH']) {  ?><li><a href="<?php echo (isset($this->_rootref['U_SEARCH'])) ? $this->_rootref['U_SEARCH'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_SEARCH_ADV_EXPLAIN'])) ? $this->_rootref['L_SEARCH_ADV_EXPLAIN'] : ((isset($user->lang['SEARCH_ADV_EXPLAIN'])) ? $user->lang['SEARCH_ADV_EXPLAIN'] : '{ SEARCH_ADV_EXPLAIN }')); ?>"><?php echo ((isset($this->_rootref['L_SEARCH'])) ? $this->_rootref['L_SEARCH'] : ((isset($user->lang['SEARCH'])) ? $user->lang['SEARCH'] : '{ SEARCH }')); ?></a></li><?php } if (! $this->_rootref['S_IS_BOT'] && $this->_rootref['S_USER_LOGGED_IN']) {  ?>
		<li><a href="<?php echo (isset($this->_rootref['U_PROFILE'])) ? $this->_rootref['U_PROFILE'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_PROFILE'])) ? $this->_rootref['L_PROFILE'] : ((isset($user->lang['PROFILE'])) ? $user->lang['PROFILE'] : '{ PROFILE }')); ?>" accesskey="e"><?php echo ((isset($this->_rootref['L_PROFILE'])) ? $this->_rootref['L_PROFILE'] : ((isset($user->lang['PROFILE'])) ? $user->lang['PROFILE'] : '{ PROFILE }')); ?></a></li>
		<?php } if (! $this->_rootref['S_IS_BOT'] && $this->_rootref['S_USER_LOGGED_IN']) {  if ($this->_rootref['S_DISPLAY_PM']) {  ?><li><a href="<?php echo (isset($this->_rootref['U_PRIVATEMSGS'])) ? $this->_rootref['U_PRIVATEMSGS'] : ''; ?>"><?php echo (isset($this->_rootref['PRIVATE_MESSAGE_INFO'])) ? $this->_rootref['PRIVATE_MESSAGE_INFO'] : ''; ?></a></li><?php } if ($this->_rootref['S_DISPLAY_SEARCH']) {  ?>
		<li><a href="<?php echo (isset($this->_rootref['U_SEARCH_SELF'])) ? $this->_rootref['U_SEARCH_SELF'] : ''; ?>"><?php echo ((isset($this->_rootref['L_SEARCH_SELF'])) ? $this->_rootref['L_SEARCH_SELF'] : ((isset($user->lang['SEARCH_SELF'])) ? $user->lang['SEARCH_SELF'] : '{ SEARCH_SELF }')); ?></a></li>
		<?php } if ($this->_rootref['U_RESTORE_PERMISSIONS']) {  ?>
		<li><a href="<?php echo (isset($this->_rootref['U_RESTORE_PERMISSIONS'])) ? $this->_rootref['U_RESTORE_PERMISSIONS'] : ''; ?>"><?php echo ((isset($this->_rootref['L_RESTORE_PERMISSIONS'])) ? $this->_rootref['L_RESTORE_PERMISSIONS'] : ((isset($user->lang['RESTORE_PERMISSIONS'])) ? $user->lang['RESTORE_PERMISSIONS'] : '{ RESTORE_PERMISSIONS }')); ?></a></li>
		<?php } } if (! $this->_rootref['S_USER_LOGGED_IN'] && $this->_rootref['S_REGISTER_ENABLED'] && ! ( $this->_rootref['S_SHOW_COPPA'] || $this->_rootref['S_REGISTRATION'] )) {  ?><li><a href="<?php echo (isset($this->_rootref['U_REGISTER'])) ? $this->_rootref['U_REGISTER'] : ''; ?>"><?php echo ((isset($this->_rootref['L_REGISTER'])) ? $this->_rootref['L_REGISTER'] : ((isset($user->lang['REGISTER'])) ? $user->lang['REGISTER'] : '{ REGISTER }')); ?></a></li><?php } ?>
				<li><a href="<?php echo (isset($this->_rootref['U_LOGIN_LOGOUT'])) ? $this->_rootref['U_LOGIN_LOGOUT'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_LOGIN_LOGOUT'])) ? $this->_rootref['L_LOGIN_LOGOUT'] : ((isset($user->lang['LOGIN_LOGOUT'])) ? $user->lang['LOGIN_LOGOUT'] : '{ LOGIN_LOGOUT }')); ?>" accesskey="x"><?php echo ((isset($this->_rootref['L_LOGIN_LOGOUT'])) ? $this->_rootref['L_LOGIN_LOGOUT'] : ((isset($user->lang['LOGIN_LOGOUT'])) ? $user->lang['LOGIN_LOGOUT'] : '{ LOGIN_LOGOUT }')); ?></a></li>
		<?php } ?>
<?php } ?>
				<a href="<?php echo (isset($this->_rootref['U_INDEX'])) ? $this->_rootref['U_INDEX'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_INDEX'])) ? $this->_rootref['L_INDEX'] : ((isset($user->lang['INDEX'])) ? $user->lang['INDEX'] : '{ INDEX }')); ?>" id="logo"><?php echo (isset($this->_rootref['SITE_LOGO_IMG'])) ? $this->_rootref['SITE_LOGO_IMG'] : ''; ?></a>
				<!-- <h1><?php echo (isset($this->_rootref['SITENAME'])) ? $this->_rootref['SITENAME'] : ''; ?></h1>
				<p><?php echo (isset($this->_rootref['SITE_DESCRIPTION'])) ? $this->_rootref['SITE_DESCRIPTION'] : ''; ?></p> -->
				<p class="skiplink"><a href="#start_here"><?php echo ((isset($this->_rootref['L_SKIP'])) ? $this->_rootref['L_SKIP'] : ((isset($user->lang['SKIP'])) ? $user->lang['SKIP'] : '{ SKIP }')); ?></a></p>
			<?php if ($this->_rootref['S_DISPLAY_SEARCH'] && ! $this->_rootref['S_IN_SEARCH']) {  ?>
				<form action="<?php echo (isset($this->_rootref['U_SEARCH'])) ? $this->_rootref['U_SEARCH'] : ''; ?>" method="post" id="search">
				<fieldset>
					<input name="keywords" id="keywords" type="text" maxlength="128" title="<?php echo ((isset($this->_rootref['L_SEARCH_KEYWORDS'])) ? $this->_rootref['L_SEARCH_KEYWORDS'] : ((isset($user->lang['SEARCH_KEYWORDS'])) ? $user->lang['SEARCH_KEYWORDS'] : '{ SEARCH_KEYWORDS }')); ?>" class="inputbox search" value="<?php if ($this->_rootref['SEARCH_WORDS']) {  echo (isset($this->_rootref['SEARCH_WORDS'])) ? $this->_rootref['SEARCH_WORDS'] : ''; } else { echo ((isset($this->_rootref['L_SEARCH_MINI'])) ? $this->_rootref['L_SEARCH_MINI'] : ((isset($user->lang['SEARCH_MINI'])) ? $user->lang['SEARCH_MINI'] : '{ SEARCH_MINI }')); } ?>" onclick="if(this.value=='<?php echo ((isset($this->_rootref['LA_SEARCH_MINI'])) ? $this->_rootref['LA_SEARCH_MINI'] : ((isset($this->_rootref['L_SEARCH_MINI'])) ? addslashes($this->_rootref['L_SEARCH_MINI']) : ((isset($user->lang['SEARCH_MINI'])) ? addslashes($user->lang['SEARCH_MINI']) : '{ SEARCH_MINI }'))); ?>')this.value='';" onblur="if(this.value=='')this.value='<?php echo ((isset($this->_rootref['LA_SEARCH_MINI'])) ? $this->_rootref['LA_SEARCH_MINI'] : ((isset($this->_rootref['L_SEARCH_MINI'])) ? addslashes($this->_rootref['L_SEARCH_MINI']) : ((isset($user->lang['SEARCH_MINI'])) ? addslashes($user->lang['SEARCH_MINI']) : '{ SEARCH_MINI }'))); ?>';" />
					<input class="button2" value="<?php echo ((isset($this->_rootref['L_SEARCH'])) ? $this->_rootref['L_SEARCH'] : ((isset($user->lang['SEARCH'])) ? $user->lang['SEARCH'] : '{ SEARCH }')); ?>" type="submit" /><br />
				</fieldset>
				</form>
		<?php } ?>
<?php if (! $this->_tpldata['DEFINE']['.']['S_IN_PORTAL'] || $this->_rootref['S_DISPLAY_PHPBB_MENU']) {  ?>
				<li class="icon-home"><?php if ($this->_rootref['U_PORTAL']) {  ?><a href="<?php echo (isset($this->_rootref['U_PORTAL'])) ? $this->_rootref['U_PORTAL'] : ''; ?>"><?php echo ((isset($this->_rootref['L_PORTAL'])) ? $this->_rootref['L_PORTAL'] : ((isset($user->lang['PORTAL'])) ? $user->lang['PORTAL'] : '{ PORTAL }')); ?></a> &#187; <?php } ?><a href="<?php echo (isset($this->_rootref['U_INDEX'])) ? $this->_rootref['U_INDEX'] : ''; ?>" accesskey="h"><?php echo ((isset($this->_rootref['L_INDEX'])) ? $this->_rootref['L_INDEX'] : ((isset($user->lang['INDEX'])) ? $user->lang['INDEX'] : '{ INDEX }')); ?></a> <?php $_navlinks_count = (isset($this->_tpldata['navlinks'])) ? sizeof($this->_tpldata['navlinks']) : 0;if ($_navlinks_count) {for ($_navlinks_i = 0; $_navlinks_i < $_navlinks_count; ++$_navlinks_i){$_navlinks_val = &$this->_tpldata['navlinks'][$_navlinks_i]; ?> <strong>&#8249;</strong> <a href="<?php echo $_navlinks_val['U_VIEW_FORUM']; ?>"><?php echo $_navlinks_val['FORUM_NAME']; ?></a><?php }} ?></li>
				<li class="rightside"><a href="#" onclick="fontsizeup(); return false;" onkeypress="return fontsizeup(event);" class="fontsize" title="<?php echo ((isset($this->_rootref['L_CHANGE_FONT_SIZE'])) ? $this->_rootref['L_CHANGE_FONT_SIZE'] : ((isset($user->lang['CHANGE_FONT_SIZE'])) ? $user->lang['CHANGE_FONT_SIZE'] : '{ CHANGE_FONT_SIZE }')); ?>"><?php echo ((isset($this->_rootref['L_CHANGE_FONT_SIZE'])) ? $this->_rootref['L_CHANGE_FONT_SIZE'] : ((isset($user->lang['CHANGE_FONT_SIZE'])) ? $user->lang['CHANGE_FONT_SIZE'] : '{ CHANGE_FONT_SIZE }')); ?></a></li>
				<?php if ($this->_rootref['U_EMAIL_TOPIC']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_EMAIL_TOPIC'])) ? $this->_rootref['U_EMAIL_TOPIC'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_EMAIL_TOPIC'])) ? $this->_rootref['L_EMAIL_TOPIC'] : ((isset($user->lang['EMAIL_TOPIC'])) ? $user->lang['EMAIL_TOPIC'] : '{ EMAIL_TOPIC }')); ?>" class="sendemail"><?php echo ((isset($this->_rootref['L_EMAIL_TOPIC'])) ? $this->_rootref['L_EMAIL_TOPIC'] : ((isset($user->lang['EMAIL_TOPIC'])) ? $user->lang['EMAIL_TOPIC'] : '{ EMAIL_TOPIC }')); ?></a></li><?php } if ($this->_rootref['U_EMAIL_PM']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_EMAIL_PM'])) ? $this->_rootref['U_EMAIL_PM'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_EMAIL_PM'])) ? $this->_rootref['L_EMAIL_PM'] : ((isset($user->lang['EMAIL_PM'])) ? $user->lang['EMAIL_PM'] : '{ EMAIL_PM }')); ?>" class="sendemail"><?php echo ((isset($this->_rootref['L_EMAIL_PM'])) ? $this->_rootref['L_EMAIL_PM'] : ((isset($user->lang['EMAIL_PM'])) ? $user->lang['EMAIL_PM'] : '{ EMAIL_PM }')); ?></a></li><?php } if ($this->_rootref['U_PRINT_TOPIC']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_PRINT_TOPIC'])) ? $this->_rootref['U_PRINT_TOPIC'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_PRINT_TOPIC'])) ? $this->_rootref['L_PRINT_TOPIC'] : ((isset($user->lang['PRINT_TOPIC'])) ? $user->lang['PRINT_TOPIC'] : '{ PRINT_TOPIC }')); ?>" accesskey="p" class="print"><?php echo ((isset($this->_rootref['L_PRINT_TOPIC'])) ? $this->_rootref['L_PRINT_TOPIC'] : ((isset($user->lang['PRINT_TOPIC'])) ? $user->lang['PRINT_TOPIC'] : '{ PRINT_TOPIC }')); ?></a></li><?php } if ($this->_rootref['U_PRINT_PM']) {  ?><li class="rightside"><a href="<?php echo (isset($this->_rootref['U_PRINT_PM'])) ? $this->_rootref['U_PRINT_PM'] : ''; ?>" title="<?php echo ((isset($this->_rootref['L_PRINT_PM'])) ? $this->_rootref['L_PRINT_PM'] : ((isset($user->lang['PRINT_PM'])) ? $user->lang['PRINT_PM'] : '{ PRINT_PM }')); ?>" accesskey="p" class="print"><?php echo ((isset($this->_rootref['L_PRINT_PM'])) ? $this->_rootref['L_PRINT_PM'] : ((isset($user->lang['PRINT_PM'])) ? $user->lang['PRINT_PM'] : '{ PRINT_PM }')); ?></a></li><?php } ?>
			<?php if (! $this->_rootref['S_IS_BOT'] && $this->_rootref['S_USER_LOGGED_IN']) {  ?>
			<li><?php if ($this->_rootref['S_USER_LOGGED_IN']) {  echo (isset($this->_rootref['LAST_VISIT_DATE'])) ? $this->_rootref['LAST_VISIT_DATE'] : ''; } else { echo (isset($this->_rootref['CURRENT_TIME'])) ? $this->_rootref['CURRENT_TIME'] : ''; } ?></li>
			<?php } ?>
				<li><?php if ($this->_rootref['S_USER_LOGGED_IN']) {  } else { echo (isset($this->_rootref['CURRENT_TIME'])) ? $this->_rootref['CURRENT_TIME'] : ''; } ?></li>
			<?php if (! $this->_rootref['S_USER_LOGGED_IN'] && ! $this->_rootref['S_IS_BOT']) {  ?>
	<form method="post" action="<?php echo (isset($this->_rootref['S_LOGIN_ACTION'])) ? $this->_rootref['S_LOGIN_ACTION'] : ''; ?>">
			<label for="username"><?php echo ((isset($this->_rootref['L_USERNAME'])) ? $this->_rootref['L_USERNAME'] : ((isset($user->lang['USERNAME'])) ? $user->lang['USERNAME'] : '{ USERNAME }')); ?>:</label>&nbsp;<input type="text" name="username" id="username" size="10" class="inputbox" title="<?php echo ((isset($this->_rootref['L_USERNAME'])) ? $this->_rootref['L_USERNAME'] : ((isset($user->lang['USERNAME'])) ? $user->lang['USERNAME'] : '{ USERNAME }')); ?>" />
			<label for="password"><?php echo ((isset($this->_rootref['L_PASSWORD'])) ? $this->_rootref['L_PASSWORD'] : ((isset($user->lang['PASSWORD'])) ? $user->lang['PASSWORD'] : '{ PASSWORD }')); ?>:</label>&nbsp;<input type="password" name="password" id="password" size="10" class="inputbox" title="<?php echo ((isset($this->_rootref['L_PASSWORD'])) ? $this->_rootref['L_PASSWORD'] : ((isset($user->lang['PASSWORD'])) ? $user->lang['PASSWORD'] : '{ PASSWORD }')); ?>" />
			<input type="submit" name="login" value="<?php echo ((isset($this->_rootref['L_LOGIN'])) ? $this->_rootref['L_LOGIN'] : ((isset($user->lang['LOGIN'])) ? $user->lang['LOGIN'] : '{ LOGIN }')); ?>" class="button2" />
			<?php echo (isset($this->_rootref['S_LOGIN_REDIRECT'])) ? $this->_rootref['S_LOGIN_REDIRECT'] : ''; ?>
	</form>
<?php } ?>
	<?php if ($this->_rootref['ADS_2']) {  ?>
				<li class="header">
					<dl class="icon">
						<dt><?php echo ((isset($this->_rootref['L_ADVERTISEMENT'])) ? $this->_rootref['L_ADVERTISEMENT'] : ((isset($user->lang['ADVERTISEMENT'])) ? $user->lang['ADVERTISEMENT'] : '{ ADVERTISEMENT }')); ?></dt>
					</dl>
				</li>
				<?php echo (isset($this->_rootref['ADS_2'])) ? $this->_rootref['ADS_2'] : ''; ?>
	<?php } ?>
		<?php if ($this->_rootref['S_BOARD_DISABLED'] && $this->_rootref['S_USER_LOGGED_IN'] && ( $this->_rootref['U_MCP'] || $this->_rootref['U_ACP'] )) {  ?>
				<strong><?php echo ((isset($this->_rootref['L_INFORMATION'])) ? $this->_rootref['L_INFORMATION'] : ((isset($user->lang['INFORMATION'])) ? $user->lang['INFORMATION'] : '{ INFORMATION }')); ?>:</strong> <?php echo ((isset($this->_rootref['L_BOARD_DISABLED'])) ? $this->_rootref['L_BOARD_DISABLED'] : ((isset($user->lang['BOARD_DISABLED'])) ? $user->lang['BOARD_DISABLED'] : '{ BOARD_DISABLED }')); ?>
		<?php } ?>
please help anyone
ghostman
Post by ghostman »
You missed an <!--ENDIF --> in line 196
remember to do all edits from install.xml ;)
Maybe it should be placed after the add2 Mod code, but you have to try to see what happens and then edit if needed.
Edited code with the fix:
overall_header.html
    <head>
    {META}
    // <![CDATA[
          if ({S_NEW_PM})
       * Find a member
          return false;
    </script>
    </head>
       <div id="wrap">
                {ADS_1}
          <ul>
                <fieldset>
                </fieldset>
                </form>
             {S_LOGIN_REDIRECT}
       </form>
       <!-- IF ADS_2 -->
                <li class="header">
                   <dl class="icon">
                   </dl>
                </li>
                {ADS_2}
Remember to take backups etc .. etc
/Ghostman
gisfreak
Post by gisfreak »
ghostman wrote:You missed an <!--ENDIF --> in line 196
wow how come, i do exactly as install.xml said :o
or maybe i should install portal first then the 2 mod after that, any incompatibility maybe ?
dont worry, i use localhost before using in real forum, so no need to worry if its crash :D
thanx mate , really appreciate, i will try it first and give you report
ghostman
Post by ghostman »
In the overall_header.html you posted in this thred I saw that the last edit in overall_header.html was missing, or placed in a differnt line
This was missing from install.xml
FIND:
Add after:
That "<!-- ENDIF -->" wasent there, but you can have placed it in a different line, I dont know in what mod you installed first, and what you installed last ;)
But again the error message
could also be caused by a typo error, I know that from experience :P
/Ghostman
gisfreak
Post by gisfreak »
hum, so here what i do, just replace the old overall_header.html
delete cache file
and reload the browser
and still
hum i will try to check it again ;)
could it be unsupported themes ? or incompatible mod ?
first time i install adaptive hide bb code and success after that i install ad management and success, and then the last is this portal, and failed :oops:
ghostman
Post by ghostman »
Now I have installed the style on my testboard, and maked the style edits for the portal. I did it on a clean phpbb3 forum without any other mods installed, and it works.
Try to install the portal on a fresh phpbb3, and see if it still give problems, and then if it dont, add your 2 other mods one by one.
What works for me:
NOTICE ... You 2 other mods edits are NOT included in this code.
overall_header.html
<head>
{META}
// <![CDATA[
		if ({S_NEW_PM})
	* Find a member
		return false;
</script>
</head>
	<div id="wrap">
		<ul>
				<fieldset>
				</fieldset>
				</form>
			{S_LOGIN_REDIRECT}
	</form>
/Ghostman
gisfreak
Post by gisfreak »
hum, maybe i should try to install portal first and then the advertisement management, okey
i will try it and give you report ;)
gisfreak
Post by gisfreak »
ah at last problem solved, i found it in another post , here
http://board3.de/viewtopic.php?f=10&t=3658&start=15
in overall_header, there are instalation step that
search
and add after
unfortunately , i cant search whole script, so i just search U_LOGIN_LOGOUT, so begin the mess, those part is wrong place to add those endif :lol:
and in post
http://board3.de/viewtopic.php?f=10&t=3658&start=15#p23508
, MARC said, that those endif must be add before
and after i edit that, whalaaaaaaaaaaa...........portal show up
maybe in install.xml, we should add this rather than prev step, so confusing :roll:
nice mate , thanx
The install.xml says to search for the code mentioned above and tells you to add the code after it.
The code I mentioned is right after the code you were supposed to look for. If you add the code right in front of it, it's still the same place.
