Twitter on portal board
Weltall
phpBB.com User: Weltall
Post by Weltall »
Your Portal Version: 1.0.6RC3
Boardlink: http://decimabc2.it
Searching on the web i discovered a project wich allow to have a twitter box on homepage,allowing users to be updated in real time about the channel they select.
I tried to intall this thing but it doesn't seems to work for me.
Here is the project link: rem blog
and here it is the code I applyed in my block:
{$LR_BLOCK_H_L} Official BFBC2 Twitter {$LR_BLOCK_H_R}
<table class="tablebg" cellspacing="1" width="100%" >
   <tr class="row1">
      <td style="text-align:center;">
<script   src="http://twitterjs.googlecode.com/svn/trunk/src/twitter.min.js"  type="text/javascript">
</script>
<script type="text/javascript" charset="utf-8">
getTwitters('tweet', {
  count: 2,
  enableLinks: true,
  ignoreReplies: true,
  clearContents: true,
  template: '"%text%" <a href="http://twitter.com/%user_screen_name%/statuses/%id%/">%time%</a>
  <hr width="50%">'
</script>
<div id="tweet">
 <p>Tweet sta caricando...</p>
 <p><a href="http://twitter.com/OfficialBFBC2">Se non puoi aspettare - clicca qui!</a></p>
I know this may be not the right place to post this problem,but support on that blog did not answered me,and maybe i only missed a stupid thing and you can help me...
thanks anyway[/i]
Re: Twitter on portal board
This line is causing an error:
And this is the error:
unterminated string literal
And you are right, this is not the right place to ask for support. If you have an issue with a script, then please ask the script author for support or ask at phpBB.com.
