Your Portal Version: 1.0.5
Boardlink: http://www.legionofjeepers.com/forums
PHP Version: 3.0.7 PL1
MySQL Version: MySQL(i) 5.1.39
Move portal to the root of my domain while phpbb forum is under ../forums
Checked board path under server settings
So, pretty simple question, but not sure what the answer is. In the Search block on my portal, it searches Posts without issue. When searching by Author, it brings me to a Search Broken page. The landing URL is http://www.legionofjeepers.com/search.php?author=travis. As mentioned above, my portal was moved from the forums directory to be in the root, which is where I think the problem is. The path in my server settings is set to /forums, so I am clueless where else to look. Thanks in advance for any help.
Search by Author not working from Portal
