2nd, 3rd, 4th (etc) Portals?
Bash
- phpBB.de User: Bash
- phpBB.com User: Bash
Your Portal Version: 1.0.5
Is it possible to have mulitple portals on the same site? (and renaming the additional portals)
Thanks.
Thanks.
Re: 2nd, 3rd, 4th (etc) Portals?
It is certainly not impossible, but you would have to edit a lot of files.
Bash
I can do that
So extra portals wouldn't require any additional installs/SQL queries, it's just a case of re-creating the portal files, renaming them and editing them?
The problem I'm faced with at the moment, is if I start moving portal blocks to different custom pages, I have to edit the main portal file (forget which now) to exclude the blocks from the main portal to prevent duplicates (instead of disabling them through ACP) and of course, the changes I make to the portal page in ACP would effect the custom pages which is fine so long as I remember which block is where etc etc (but I want to do it properly).
Bash
Ok I found an easier option for my needs. I created a seperate menu within ACP Mods tab and added the new duplicated/renamed modules which will make it a little more organised (I didn't want to manage modules for custom pages within the portal menu).
I managed to create a module duplicated from the news module (called 'Results') and another module duplicated from the recent posts module (called 'Streams'). Heres how it looks so far: http://www.worldclanleague.com/forum/wcl.php
Now then, I have another problem...
I tried to add another block/module (called 'Videos') which is exactly the same as the streams module/block (or recent posts) but, what happened was, both the 'Streams' & 'Videos' blocks results merged - both displaying recent posts defined by each seperate module within ACP.
Let me try and explain it easier
In ACP
Module1 is pulling posts from 'Forum1'
Module2 is pulling posts from 'Forum2'
Result
Module1 (Streams block) is displaying posts from 'Forum1' & 'Forum2'
Module2 (Videos block) is pulling posts from 'Forum1' & 'Forum2'
I find it puzzling... I think it's because both the blocks are on the same page (the portal.php 'recent results' block isn't displaying the 'streams' blocks posts and vice-versa).
Sorry to bother you again, but can someone please advise me on how I can seperate these modules properly, so that their output isn't merged?
Thank you.
In ACP
Result
Thank you.
Please post the code of the blocks files of your stream & videos block, and the template files of those 2 blocks.
Bash
*is optimistic*
Streams.php
Videos.php
Streams.html
videos.html
Really appreciate this, I will have to buy you a drink for all the help you give to everyone
Streams.php
* @package - Board3portal
* @version $Id: streams.php 589 2009-12-04 21:11:16Z marc1706 $
exit;
// Exclude forums
$sql_where = '';
if ($portal_config['portal_streams_forum'] > 0)
$exclude_forums = explode(',', $portal_config['portal_streams_forum']);
$sql_where = ' AND ' . $db->sql_in_set('forum_id', $exclude_forums, ($portal_config['portal_exclude_forums']) ? true : false);
// Get a list of forums the user cannot read
$forum_ary = array_unique(array_keys($auth->acl_getf('!f_read', true)));
// Determine first forum the user is able to read (must not be a category)
$sql = 'SELECT forum_id
FROM ' . FORUMS_TABLE . '
WHERE forum_type = ' . FORUM_POST;
$forum_sql = '';
if (sizeof($forum_ary))
$sql .= ' AND ' . $db->sql_in_set('forum_id', $forum_ary, true);
$forum_sql = ' AND ' . $db->sql_in_set('t.forum_id', $forum_ary, true);
$g_forum_id = (int) $db->sql_fetchfield('forum_id');
// Streams announcements
$sql = 'SELECT topic_title, forum_id, topic_id
FROM ' . TOPICS_TABLE . ' t
WHERE topic_status <> ' . FORUM_LINK . '
AND topic_approved = 1
AND (topic_type = ' . POST_ANNOUNCE . ' OR topic_type = ' . POST_GLOBAL . ')
AND topic_moved_id = 0
' . $sql_where . '' . $forum_sql . '
ORDER BY topic_time DESC';
$result = $db->sql_query_limit($sql, $portal_config['portal_max_topics']);
while(($row = $db->sql_fetchrow($result)) && ($row['topic_title']))
// auto auth
if (($auth->acl_get('f_read', $row['forum_id'])) || ($row['forum_id'] == '0'))
$template->assign_block_vars('latest_announcements', array(
'TITLE' => character_limit($row['topic_title'], $portal_config['portal_streams_title_limit']),
'FULL_TITLE' => censor_text($row['topic_title']),
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($row['forum_id'] == 0) ? $g_forum_id : $row['forum_id']) . '&t=' . $row['topic_id'])
$db->sql_freeresult($result);
// Streams hot topics
WHERE topic_approved = 1
AND topic_replies >=' . $config['hot_threshold'] . '
// auto auth
$template->assign_block_vars('latest_hot_topics', array(
// Streams topic (only show normal topic)
WHERE topic_status <> ' . ITEM_MOVED . '
AND topic_type = ' . POST_NORMAL . '
// auto auth
$template->assign_block_vars('latest_topics', array(
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $row['forum_id'] . '&t=' . $row['topic_id'])
$template->assign_var('S_DISPLAY_STREAMS', true);
?>Code: Select all
* @version $Id: videos.php 589 2009-12-04 21:11:16Z marc1706 $
exit;
// Exclude forums
$sql_where = '';
if ($portal_config['portal_videos_forum'] > 0)
$exclude_forums = explode(',', $portal_config['portal_videos_forum']);
$forum_sql = '';
// Videos announcements
// auto auth
'TITLE' => character_limit($row['topic_title'], $portal_config['portal_videos_title_limit']),
// Videos hot topics
// auto auth
// Videos topic (only show normal topic)
// auto auth
$template->assign_var('S_DISPLAY_VIDEOS', true);
?>Code: Select all
<!--version $Id: streams.html 503 2009-04-20 18:34:29Z kevin74 $ //-->
<!-- IF .latest_announcements or .latest_hot_topics or .latest_topics -->
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_THEME_PATH}/images/portal/portal_stats.png" width="16" height="16" alt="" /> <!-- ENDIF -->Streams{$LR_BLOCK_H_R}
<tr class="row1">
<td class="row1" width="100%" valign="top">
<!-- IF .latest_announcements -->
<!-- BEGIN latest_announcements -->
<a href="{latest_announcements.U_VIEW_TOPIC}" title="{latest_announcements.FULL_TITLE}">{latest_announcements.TITLE}</a><br />
<!-- END latest_announcements -->
<!-- IF .latest_hot_topics -->
<!-- BEGIN latest_hot_topics -->
<a href="{latest_hot_topics.U_VIEW_TOPIC}" title="{latest_hot_topics.FULL_TITLE}">{latest_hot_topics.TITLE}</a><br />
<!-- END latest_hot_topics -->
<!-- IF .latest_topics -->
<!-- BEGIN latest_topics -->
<a href="{latest_topics.U_VIEW_TOPIC}" title="{latest_topics.FULL_TITLE}">{latest_topics.TITLE}</a><br />
<!-- END latest_topics -->
<!--version $Id: videos.html 503 2009-04-20 18:34:29Z kevin74 $ //-->
{$LR_BLOCK_H_L}<!-- IF $S_BLOCK_ICON --><img src="{T_THEME_PATH}/images/portal/portal_stats.png" width="16" height="16" alt="" /> <!-- ENDIF -->Recent videos{$LR_BLOCK_H_R}
<tr class="row1">
<!-- ENDIF -->-
Bash
No?
(sorry to be impatient)
You are overwriting your block's block vars. Take a look here, maybe that clears it up for you (especially the assign_block_vars):
http://wiki.phpbb.com/display/MODDOCS/T ... ate+syntax
Bash
No idea what I'm looking at there tbh
Ok, I'll give you an example. You have this code in your streams block:
You are assigning block vars to the block "latest_announcements". At the same time, you have this code in your video block:
So you are writing to the same block. The problem is, that you are actually overwriting the initial "latest_announcements" block. So in order to fix this, you will have to choose different names for your template blocks. Once you have done that in the php files, you will also have to that in the HTML files.
For example if your change your block name to 'latest_announcements_videos', you will have to change this in the HTML file:
));Code: Select all
));For example if your change your block name to 'latest_announcements_videos', you will have to change this in the HTML file:
<!-- IF .latest_announcements_videos -->
<!-- BEGIN latest_announcements_videos -->
<a href="{latest_announcements_videos.U_VIEW_TOPIC}" title="{latest_announcements_videos.FULL_TITLE}">{latest_announcements_videos.TITLE}</a><br />
<!-- END latest_announcements_videos -->
<!-- ENDIF -->-
Bash
Thank you so much Marc <3
Bash
Hello Marc,
I'm now trying to install a second portal, which I've renamed wcl. I've renamed every instance of portal and PORTAL to wcl and WCL within the files respectively. I also renamed language/en/mods/additional_blocks.php and info_acp_additional_blocks.php to additional_wcl_blocks and info_acp_additional_wcl_blocks.php respectively, and all references to those files in the other files (to avoid overwriting).
After installing, the forum went down:
The additions I made to functions.php which cause this, were:
And clue as to what I could try?
Thanks very much
Fatal error: Cannot redeclare phpbb_fetch_posts() (previously declared in /home/neblncbt/public_html/forum/portal/includes/functions.php:61) in /home/neblncbt/public_html/forum/wcl/includes/functions.php on line 323Code: Select all
// Portal
$user->add_lang(array('mods/lang_portal', 'mods/additional_blocks'));
if(sql_table_exists(PORTAL_CONFIG_TABLE) == true)
// WCL
$user->add_lang(array('mods/lang_wcl', 'mods/additional_wcl_blocks'));
if (!function_exists('obtain_wcl_config'))
include($phpbb_root_path . 'wcl/includes/functions.' . $phpEx);
if(sql_table_exists(WCL_CONFIG_TABLE) == true)
$wcl_config = obtain_wcl_config();
}Thanks very much
Bash
Fixed. I just had to rename all the functions within portal/includes/functions.php.
matius
Can anyone tell how to do it step by step? He was very grateful because I'm not too good this
