Boardlink: http://astra.gwave23.com
Nothing
Tried to do the style edits.
I can't seem to get the edits right for my theme. The theme is called eTech and is based on subsilver2.
I tried the subsilver2 edits but I must be putting them in the wrong place.
I only need help with the overall_header.html
Im not sure where to the the instructions as some of the lines I have to search for don't exist.
Here is my overall_header.html file:
<head>
<!-- INCLUDE ca_config.html -->
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
{META}
<title>{SITENAME} - <!-- IF S_IN_MCP -->{L_MCP} - <!-- ELSEIF S_IN_UCP -->{L_UCP} - <!-- ENDIF -->{PAGE_TITLE}</title>
<!-- IF S_ENABLE_FEEDS -->
<!--[if IE]>
<link rel="stylesheet" type="text/css" href="{T_THEME_PATH}/ie7.css" />
<![endif]-->
// <![CDATA[
	var ca_main_width = '{$CA_WIDTH}';
<!-- IF S_USER_PM_POPUP -->
	if ({S_NEW_PM})
	if (!name)
		name = '_popup';
	return false;
function jumpto()
	var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
	return false;
* Mark/unmark checklist
	if (!parent)
	if (!parent)
		return;
			rb[r].checked = state;
<!-- IF ._file -->
	function play_qt_file(obj)
		if (rectangle)
			var width = 200;
			var height = 0;
		obj.width = width;
		obj.height = height + 16;
		obj.Play();
	window.onload = function()
			eval(onload_functions[i]);
	window.onunload = function()
			eval(onunload_functions[i]);
if(navigator.userAgent && navigator.userAgent.indexOf('Mac OS X') > 0)
	document.write('<link rel="stylesheet" href="{T_THEME_PATH}/mac.css" type="text/css" />');
if(navigator.userAgent && navigator.userAgent.indexOf('AppleWebKit') > 0)
	document.write('<link rel="stylesheet" href="{T_THEME_PATH}/safari.css" type="text/css" />');
</script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/ca_scripts.js"></script>
</head>
<a name="top"></a>
<table border="0" cellspacing="0" cellpadding="0" width="{$CA_WIDTH}" id="maintable" align="center">
	<td id="logorow" align="center"><div id="logotop">
		<a href="{U_INDEX}">{SITE_LOGO_IMG}</a>
	</div></td>
	<td class="navrow">
		<!-- IF not S_IS_BOT -->
			<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}">{L_PROFILE}</a> • <!-- ENDIF -->
				<!-- IF S_DISPLAY_PM --><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a> • <!-- ENDIF -->
			<!-- ELSEIF S_REGISTER_ENABLED and not (S_SHOW_COPPA or S_REGISTRATION) --><a href="{U_REGISTER}">{L_REGISTER}</a> • <!-- ENDIF -->
		<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}">{L_RESTORE_PERMISSIONS}</a> • <!-- ENDIF -->
		<a href="{U_FAQ}">{L_FAQ}</a>
		<!-- IF S_DISPLAY_SEARCH --> • <a href="{U_SEARCH}">{L_SEARCH}</a><!-- ENDIF -->
			<!-- IF S_DISPLAY_MEMBERLIST --> • <a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a><!-- ENDIF -->
		<!-- IF not S_IS_BOT --> • <a href="{U_LOGIN_LOGOUT}">{L_LOGIN_LOGOUT}</a><!-- ENDIF -->
	<td id="contentrow">
<!-- IF not S_IS_BOT && not $CA_SKIP_PM_NOTIFY && S_USER_LOGGED_IN && S_DISPLAY_PM -->
	<!-- IF S_USER_NEW_PRIVMSG -->
		<div class="pm-notify-new"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
	<!-- ELSEIF S_USER_UNREAD_PRIVMSG -->
		<div class="pm-notify-unread"><div class="pm-notify-header">{L_PRIVATE_MESSAGES}</div><a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}<!-- IF PRIVATE_MESSAGE_INFO_UNREAD -->, {PRIVATE_MESSAGE_INFO_UNREAD}<!-- ENDIF --></a></div>
        <td class="gensmall">
            <!-- IF S_USER_LOGGED_IN -->{LAST_VISIT_DATE}<br /><!-- ENDIF -->
            <!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH_UNANSWERED}">{L_SEARCH_UNANSWERED}</a> | <a href="{U_SEARCH_ACTIVE_TOPICS}">{L_SEARCH_ACTIVE_TOPICS}</a><!-- ENDIF -->
        <td class="gensmall" align="{S_CONTENT_FLOW_END}">
            {CURRENT_TIME}<br />
            <!-- IF S_DISPLAY_SEARCH and S_USER_LOGGED_IN --><a href="{U_SEARCH_UNREAD}">{L_SEARCH_UNREAD}</a> | <a href="{U_SEARCH_NEW}">{L_SEARCH_NEW}</a> | <a href="{U_SEARCH_SELF}">{L_SEARCH_SELF}</a><!-- ENDIF -->
