Your Portal Version: 1.0.5
Is it possible to have more than one custom block?
Nothing
Is it possible to have more than one custom block and if so can they be active simultaneously?
Thanks
I did search for this and found a solution BUT I'm afraid I can't speak or read German, Sorry
More Custom Blocks?
Re: More Custom Blocks?
Google translator is your friend. Try it. I think it is good enough to understand the basics.
psychoduck
Thank you
