Boardlink: http://classicguitare.com/portal.php
update
install automod
Hello please help
I can't see the configuration of the portal page in administration?
Thank you very much
portal in administration
Re: portal in administration
Did you run the installer?
Yes! I even tried to do it yesterday, but I have only the option to uninstall
thanks for your help
I also ran unsuccessfully install_update.php
First of, you should always access the installer via install/index.php. Secondly, please try removing the table phpbb_portal_config from your database (the prefix phpbb_ might be different). After that you should be able to install it again.
It market but I lost all info portal
Is it possible to change the order of the blocks please ?
That should help you: Knowledge Base: Moving blocks / change order
Thanks
