Your Portal Version: 1.05
Boardlink: http://www.futilityguild.com/forum/portal.php?style=6
Nothing. Just trying to change up the style a bit.
Searched all the posts, tried to compare elements with chromes element tool to see what I was missing.
Hello,
I am trying to change up the style a bit on our website and have run in an issue. I can get everything the way I want it except for the borders around the blocks\block headings.
Ive compared everything I can from my site :
with a demo site :
http://area51.mikevil.de/portal.php?style=10
And cant seem to figure out why the boarders around the blocks and block headings show on the demo and not mine.
Chances are I'm missing something pretty basic. I'm just knowledgeable enough to be dangerous.
Can someone point me in the right direction?
Thanks!
Wowking style
Re: Wowking style
the images in the contributions are too large.
You should have in the ACP "Recent Posts" to its CompaktStyle.
Please also look out here:viewtopic.php?f=47&t=3895
Re: Wowking style
Thank you for the quick reply!
I changed the News to the compact style.
And the borders still dont show. Did you mean something else?
As far as I can tell I did the install correctly. Ive checked it over and don't see anything I'm missing.
Re: Wowking style
You're not here considered:
open: styles/WoWKing/template/portal/_block_config.html
_block_config.html for WoWKing
Re: Wowking style
You guys are fast.
I had that in my _block_config.html file and just to make sure I didnt mess it up I just deleted and recreated it.
After clearing the cache still no borders.
Its odd.
Does it look like that file is just not being read?
I just noticed that the menu items look different too. Is it possible I have something wrong maybe in the prosilver files I copied over?
Its odd.
Re: Wowking style
You copied the wrong files (subsilver2).
You must copy the files of prosilver.
Re: Wowking style
I definitely copied the prosilver files over but there is nothing that says for some reason in the past I hadn't changed the files in the prosilver style with others when I was messing with something. Those files have gone though many changes (and my mistakes) through the years.
You have pointed me in the direction I needed to go and I will look at reuploading all the correct prosilver ones.
Thanks for the help!
Re: Wowking style
Yep, you are a genius.
I recopied over those files from a clean install and everything showed up as it should!
All my formatting and rearranging is gone but I can redo all of that stuff.
Thanks again!
Thanks again!
