just try this method:
replace the contents of root/styles/absolution/template/portal/_block_config.html:
<!--version $Id: _block_config.html v1.0.6 adapted by: archivar $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<div class="panel bg2"><div class="inner"><span class="corners-top"><span></span></span><h3>' -->
<!-- DEFINE $LR_BLOCK_H_R = '</h3>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="inner"><ul class="topiclist"><li class="header"><div class="custom-cat-header"><div class="custom-cat-header-left"><dl class="icon"><div class="custom-cat-header-right"></div><dt><div style="margin-left: 10px; margin-top: 4px; width: 250px;">' -->
<!-- DEFINE $C_BLOCK_H_R = '</div></dt></dl></div></div></li></ul><div class="custom-row"><ul class="topiclist forums">' -->
<!-- DEFINE $C_BLOCK_F_R = '</ul></div><div class="custom-foot"><div class="custom-foot-right"></div></div></div><br style="clear:both" />' -->
A better solution, I currently do not have.
In order to see the right and left blocks is different
