Phpbb3 + portal3 + AeroBlack style
greenfire
phpBB.de User: greenfire
phpBB.com User: greenfire
Post by greenfire »
Your Portal Version: 1.0.6
Boardlink: http://dev.unholybiker.eu
PHP Version: 5.2.6-1+lenny9
MySQL Version: 14.12 Distrib 5.0.51a
After I got myself PHPBB3 i was thinking of a portal and got to this site. Installed the portal - works great. Well it works great with the prosilver template but i wanted to run the portal and forum with the AeroBlack style. Some borders and stuff like last posts are not formatted.
I copied the portal folder from prosilver to aeroblack and tried to fix everything myself.
I've got myself firebug to locate what is where...as i said some border were missing so i just thought i can fix the template step by step.. but i think its not that easy.
Till now i just added small stuff like border-style:solid;border-width:1px; to the left, center and <!-- [+] right block area --> in portal_body.html
Is there an easy way to get the aeroblack style working with the portal if i dont want to use use the prosilver style?
Are there other "ready" styles that are already working with the portal ? In case of some database of working styles for phpbb3 + portal1.0.6?
Would be great. :)
Greetz, Greenfire
Re: Phpbb3 + portal3 + AeroBlack style
Hello
Maybe this will help you further
viewtopic.php?f=47&t=2978
greenfire
Post by greenfire »
oh nice thx - i'll try that :D
Return to “Styles Support”
