block_config.html for style Rock'n Roll
yomi
Post by yomi »
Your Portal Version: 1.0.6RC3
Boardlink: http://www.witvisforum.nl
PHP Version: phpBB 3.0.7-PL1
Just a question.
Is there for the style Rock n Roll all a _block_config.html ready.
If the _ block_config.html is not read what can a have than for block_config for this style.
Style name: Rock'n Roll
Author: _Vinny_
Style version: 1.0.0 (prosilver)
phpBB version: 3.0.7
Url for the style : http://www.phpbb.com/community/viewtopi ... &t=2012385
Thanks for your help.
Yomi ;)
Re: block_config.html for style Rock'n Roll
You can use _block_config.html of prosilver for your style.
Or you look here: viewtopic.php?f=44&t=2870
Return to “Styles Support”
