i change it name to my custom name.
i added a line in styles/prosilver/template/portal/portal_right.html with the custom block name:
<!-- INCLUDE portal/block/realm_onoff.html -->
<!--version $Id: welcome.html 521 2009-08-26 20:59:19Z christian_n $ //-->
{$C_BLOCK_H_L}<dt>{L_WELCOME}</dt>{$C_BLOCK_H_R}
<div class="panel bg1" style="margin-bottom: 0px">
<div class="content">
//noobish server settings
$sip = "127.0.0.1";
$sport = "3306";
if(realm_status($sip, $sport) === false)
echo "Server je<font color=red> Offline</font>"; // displayed text if offline(server je= server is) Offline will be red
elseif(realm_status($sip, $sport) === true)
echo "Server je <font color=green> OnLine" ; // displayed text if online(server je =server is) Onlne will be green
echo "Server je<font color=yellow> Nedostupný</font>"; // displayed text if unvailable (server je = server is)(Nedostupný= unvailable) Nedostupný will be yellow
function realm_status($host, $port)
error_reporting(0);
$etat = fsockopen($host,$port,$errno,$errstr,3);
if(!$etat){return false;}else{return true;}}
<br>----</br>
<!-- Players online right now, horde, alli, all together -->
$host = "127.0.0.1"; //db host
$user = "root"; // username
$pass = "ascent"; // password
$char_data = "characters"; // Characters db
$conn = mysql_connect($host, $user, $pass) or die(mysql_error());
mysql_select_db($char_data, $conn) or die(mysql_error());
// Every noob select
$sql = "SELECT SUM(online) FROM characters";
$sqlquery = mysql_query($sql) or die(mysql_error());
$memb = mysql_result($sqlquery,0,0);
// Alliance noobs select
$asql = "SELECT SUM(online) FROM characters WHERE race IN(1,3,4,7,11)";
$asqlquery = mysql_query($asql) or die(mysql_error());
$amemb = mysql_result($asqlquery,0,0);
// Horde noobs select
$hsql = "SELECT SUM(online) FROM characters WHERE race IN(2,5,6,8,10)";
$hsqlquery = mysql_query($hsql) or die(mysql_error());
$hmemb = mysql_result($hsqlquery,0,0);
echo "Dohromady - ".$memb."<br />"; // all noobs displayed text
echo "Alliance - ".$amemb."<br />"; // alli noobs displayed text
echo "Horda - ".$hmemb."<br />"; //horde noobs displayed text
mysql_close($conn);
<br>----</br>
<!-- total characters/noob's gfs in db ! -->
$logon = "characters"; // characters db
$porn = "realmd, auth"; // accounts db
mysql_select_db($logon, $conn) or die(mysql_error());
// characters/noob's girlfriend select
$sql = "SELECT COUNT(*) FROM characters";
$char = mysql_result($sqlquery,0,0);
echo "All characters: " . $char .""; // displayed text for noobs gfs!
<br>----</br>
<!-- All accs of all noobs in your noobish db! -->
$logon = "realmd,auth"; // acc db
mysql_select_db($porn, $conn) or die(mysql_error());
// noob's acc select
$acct_sql = "SELECT COUNT(*) FROM account";
$acct_sqlquery = mysql_query($acct_sql) or die(mysql_error());
$acc = mysql_result($acct_sqlquery,0,0);
echo "All accounts: " . $acc . ""; // displayed text for all accs
mysql_close($conn);
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
Second. Original is online_friends.html
Third. Original is custom_small.html
but no one is working...
