Boardlink: http://gamer-fusion.com
PHP Version: 3.0.8
Nothing as there is no problem
I have ventured into the portal folder and looked at the .php files.
I just want to add another link under the menu under "Privacy Policy". What file would I need to open and where would I need to add in the additional link information?
Thanks in advance!
Add link under Menu
Re: Add link under Menu
Look in the block template / portal / block / main_menu.html.P3nnyw1se wrote: Boardlink: http://gamer-fusion.com
P3nnyw1se
- phpBB.de User: P3nnyw1se
- phpBB.com User: P3nnyw1se
Will do, thanks!
