Boardlink: http://www.buhda-guild.com/
PHP Version: PHP Version 5.3.2-1ubuntu4.7
MySQL Version: 5.1.41-3ubuntu12.9
- Have added the Modules by hand into the Administrator Control Panel
- I have followed the xml by hand after the AutoMod install.
- Checked the installere like 3 times.
- Run the installer again. First run the uninstall and afterwards install it again. (Else adviced somewhere else on this forum)
After the install I can not see the board3 configuration options in the ACP.
Needed to add the modules manually to the ACP (With the Module management option)....
Now they are in the Module Manager, but still do not show up under the right catagory.
As the management is not availiblt I can not enable it at all and use it.
Basically I am missing these : acp_demo/en/ but they where added and enabled in the ACP.
Must have done something
