[Random member Block] User reputation points // 0.3.1
gamingboard
phpBB.de User: gamingboard
phpBB.com User: gamingboard
Post by gamingboard »
Note: This modification requires that the modification "user reputation points (0.3.1)" and "Board3( 1.0.6)" were installed!
Adds the user reputation points mod to the random member block...
Open "portal/block/random_member.php" and find:
$template->assign_block_vars('random_member', array(
    'USERNAME_FULL'        => get_username_string('full', $user_id, $username, $colour),
Add before:
// User reputation points - Start
// 0.3.1
$user->add_lang('mods/reputation_mod');
// User reputation points - End
Find:
Replace with:
    // 0.3.1
    'S_REPUTATION'        => $row['user_hide_reputation'] ? false : true,
    'REPUTATION'        => $row['user_reputation'],
    'REP_POWER'            => $reputation->get_rep_power($member['user_posts'], $member['user_regdate'], $row['user_reputation'], $row['group_id']),
Note: You can use this for prosilver and subsilver2!
Open "styles/prosilver/template/portal/block/random_member.html" and find:
    <!-- IF random_member.USER_FROM -->
        <span style="float:left;"><strong>{L_RND_FROM}:</strong></span><span style="float:right;padding-right:10px;"> &nbsp; {random_member.USER_FROM}</span><br style="clear:both" />
    <!-- ENDIF -->
Add after:
	<!-- IF random_member.S_REPUTATION -->
	<span style="float:left;"><strong>{L_RP_TOTAL_POINTS}:</strong></span><span style="float:right;padding-right:10px;"> &nbsp; {random_member.REPUTATION}</span><br style="clear:both" />
	<span style="float:left;"><strong>{L_RP_POWER}:</strong></span><span style="float:right;padding-right:10px;"> &nbsp; {random_member.REP_POWER}</span><br style="clear:both" />
That's all. ;)
Now upload all files and purges the cache.
(I know that the modification was abandoned >.<)
Demo:
