Just wondering real quick if the location of the portal.php file matters. Can I put that file any place that I want? Or does it have to be in a specific directory?
Thanks,
Smith
portal.php location - quick question
Smitherines
Re: portal.php location - quick question
As install.xml should tell you, it should be in the root of your forum.
