Your Portal Version: 1.0.6
Boardlink: http://vent0rz.no-ip.org:8080/nda2
I've set up a working phpBB3 board with Board3 portal. After that, I installed WowCataclysm theme (which is on the Released styles section of these boards)
I installed the ReIMG MOD, an image resizer mod, which is perfectly working on the forums, but not on the portal.
Hello there!
To begin with: nice job with the portal and kudos for your hardwork.
I've been browsing these boards for a week and I've been trying different stuff to fix this news block size issue. After finding myself unable to fix it (and feeling like an utter idiot) I decided to register and post this thread.
The thing is everything worked fine until I uploaded a high res pic, which kinda destroyed the whole portal template. I've been looking around for side margins and stuff but I've not found the code I need to edit. As I also stated, I tried addind an image resize mod, which fully works on the boards but not on the portal.
Question here is: how/what can I edit to avoid high res pics destroying the theme OR how can I get the ReIMG MOD to work on the portal site?
Thank you for your time and attention
/D~
News block image size issue!
"The past is a puzzle, like a broken mirror. As you piece it together, you cut yourself, your image keeps shifting. And you change with it.
It could destroy you, drive you mad. It could set you free."
