Your Portal Version: 1.0.6
Boardlink: http://www.destructionbreedschaos.co.uk ... portal.php
PHP Version: 4
MySQL Version: MSSQL2005 via odbc
Installed phpBB3, installed Board3Portal
Reinstalled, ensured modified files are saved in UTF8 without BOM, enabled debug in config.php.
Portal.php is visible and working in IE (and also the stock Android browser), however viewing it through Google Chrome (and the Android Dolphin HD browser) it just shows a blank page, no errors, no nothing.
Any ideas?
Thanks for the help.
Edit: Ive found the problem, it was the strripos problem referenced in the sticky. I didn't think to try that before because it was working fine in IE and I was not getting any errors (just a blank page) in the other browsers, but I figured I would give it a try and it has solved the problem.
Blank Portal.php in Google Chrome
Caijin
