Your Portal Version: 1.0.6
Boardlink: http://www.pacificgamerz.com
PHP Version: 3.08
N/a
N/a
Is there anyway to use Script for the clock block instead of the .swf?
sorry if i posted in the wrong spot. Wasn't sure where to ask a general question.
Clock .swf change to script?
scoteye
Re: Clock .swf change to script?
Take a look at styles/prosilver/template/portal/block/clock.html or styles/subsilver2/template/portal/block/clock.html depending on your style.
Just delete the clock and add your desired script.
scoteye
I had a go at editing "styles/CoDFaction/template/portal/block/clock.html" its not too important but would be nice.
I may put it on the back burner until i get the rest of the portal and themes sorted.
